Multiple CMEs
Hello everyone,
I have three sites each running CME.
I want to allow each site to dial to the other.
There are firewalls at each site, but I have allowed RTP and other voice-related protocols and signaling between the sites.
When I try to call, I get busy tones.
I get a disconnect cause=38 which tells nothing much more than a network fault but I'm not sure exactly what's the fault.
I tried different codecs but still no luck.
Following are the dial-peers applied:
voice service voip
h323
no h225 timeout keepalive
call start slow
SITE-A Configuration: (Extension range: 7XX and 8XX)
dial-peer voice 6661 voip
description <<TO SITE-B>>
destination-pattern [12]..
session target ipv4:10.10.5.1
progress_ind setup enable 3
codec g711ulaw
dial-peer voice 6662 voip
description <<TO SITE-C>>
destination-pattern 3..
session target ipv4:10.10.4.1
SITE-B Configuration: (Ext. Range: 1XX and 2XX)
description <<VOIP CONNECTION TO PORTSAID SITE>>
incoming called-number [78]..
codec g711ulaw
description <<VOIP CONNECTION TO DAMIETTA SITE>>
SITE-C Configuration: (Extension range: 3XX)
codec g711ulaw
codec g711ulaw
Any ideas?
Ahmed
Hall of Fame Super Gold
Re: Multiple CMEs
Configure a VPN between CMEs.
VoIP requires full, unrestricted connectivity.
Re: Multiple CMEs
If VPN is not an option at this point. These CMEs are connected through an MPLS network.
Any ideas?
Ahmed
Re: Multiple CMEs
Your FWs are not permitting full, transparent, any-to-any connectivity, so have fix or remove them.
Re: Multiple CMEs
Thanks Paolo for your valued input.
129
