Multiple DID ranges on CME
What needs to be done if I want to have two DID ranges and two DN ranges on CME?  Let's say
that I want to accept calls via SIP trunk from PSTN to 415-555-11XX and 650-555-22XX.
So far in telephony-service I have..
dialplan-pattern 1 41555511.. ext-length 4
dialplan-pattern 2 65055522.. ext-length 4
Having problems with the 22XX extensions getting audio internally to 22XX, 11XX, calling out
or inbound from pstn.  the 11XX is all working fine.  Any thoughts on adding this second
set of numbers is appreciated.
1 REPLY
Hall of Fame Super Gold
Most likely you have a configuration isssue causing problems.
In any case, internal calls should be fine under all circumstances.
170
