Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Multiple DID to unmatching internal Ext - CCME
Does any know of a easy way to match say 200 DID's (PRI) to unmatching internal ext numbers - without creating a huge amount of dial peers, so ie. external number
0123456789 goes to 212
0123456799 to 267 ....etc etc
The example of this is when a company moves to CCME and keeps all their old phone numbers and internal extensions.
I have managed this whith creating 200 dial peers with an exact match number with a rule directing it to the internal number ...but there must be an easyer way to do this?
Regards.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Multiple DID to unmatching internal Ext - CCME
Glad to now it worked - please remember to rate useful posts with the scrollbox below!
If the internal/external numbers are contiguous, this should help you:
http://cisco.com/en/US/docs/voice_ip_comm/cucme/bacd/configuration/guide/40did.html
If they are not, the easiest way is to configure secondary number under ephone-dn. Note, outgoing calls will be placed with the primary number however.
Thanks, nice one - this is what i am looking for, it is the non-contigous address space that was causing me issues. I presume this would just require secondaty numbers on the ext & a dialplan-pattern and a voice dial-peer to route calls correctly to the internal phones?
Thx
Just tried this with the secondary number and using a default .T dial-peer - worked a treat.
Thank you. My first mistake was that i needed to strip of the Area code from the secondary number - once i did this it worked fine.
Cheers, Wayne
It worked! Thanks.
I have a quick follow-up question. When I configure the max-time-call-retry to 60 seconds, it still keeps calls in queue for 2.5 minutes. Can you tell me why this is so?
I understand you're referring to another problem, can you clarify ?
Yes.
The CME bacd AA has a parameter for the maximum time a call will sit in the queue.
That parameter is configured under the CME AA and is called param max-time-call-retry. I've configured this for 60 seconds but the call sits in the queue for about 2.5 minutes. It's as if it's ignoring my parameter.
Try reloading the script: "call application voice load aa".
Like few others, that parameter is read only at init time.
122
