Multiple extensions, single translation pattern
All,
I have two 7905 IP phones with their own extensions. If I have a DID I'm forwarding to one phone with a translation pattern, what's the best way to get it to ring on the second phone without having to match their extensions?
I was thinking a Line Group and Hunt List combination might be a place to start, but I'm not having much luck with it.
TIA
1 ACCEPTED SOLUTION
Re: Multiple extensions, single translation pattern
Well a Line Group will be fine. Just set your TP to the Hunt Pilot instead of the actual extension and then put on the Line Group both extensions.
//Jorge
//Jorge
That did the trick. Many thanks.
142
