Community Member
Multiple Holiday Schedules for Unity Ver 4.0(5)
We are running Unity Version 4.0(5) centralized in the U.S. but supporting offices in Canada as well. Canada and the U.S. only share a few holidays which is causing us some issues. Is there any way to set up multiple holiday schedules in Unity Version 4.0(5)? How about Unity version 5.0(1)?
Hall of Fame Super Red
Re: Multiple Holiday Schedules for Unity Ver 4.0(5)
Hi John,
Multiple Holiday schedules are not supported in any current version of Unity (and I don't think in the upcoming Unity 7.0 either).
This is available in Unity Connection (which I know doesn't help you here)
Rob
Bronze
Although Multiple holiday schedules is not supported in Unity, there is a work around for the same.
Please find the following tech note which gives you the procedure.
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a008011aa09.shtml#con
Hope it helps..
Regards...
-Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
139
