Multiple LDAP on one BE6K
i know that I have redundant LDAP servers configured in CUCM. however, my situation is a bit different though.
here goes... i have one BE6K and i am using it for a single organization, but the organization is split into to parts that has totally separate Active Directory and the customer requrest that i integrate both of them on the single BE6K.
is this possible?
thanks,
Surendra
Silver
You can have multiple
You can have multiple directories pointing at multiple AD's, but the problem is authentication.
If you have authentication local, then you can pull your users from different AD's and CM will do authentication.
If you want authentication also from AD, you need something like a global AD catalog. I have no idea what that is, nor do I know what are the AD requirements to make that work.
Jan
I have a government client
I have a government client with two independently managed Active Directories. Each organizational unit needs directory and authentication services to their own AD, but wants to see the directory info for the other UC cluster. Sounds like we simply need to add the other AD info for each UC cluster's directory, right?
Are they in the same forest??
java
if this helps, please rate
www.cisco.com/go/pdi
Entirely separate domains.
Entirely separate domains. They only want to see the directories (users/phone numbers) of the other's domain.
Then you need to follow the
Then you need to follow the link I posted, or to use a custom directory script.
java
Jaime, I'm not clear on this,
Jaime,
I'm not clear on this, can you be more specific? The link you provided speaks of authentication. I only need directories so users on cluster A can see the telephone numbers of users on cluster b.
http://www.cisco.com/c/en/us
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-version-80/111979-ucm-multi-forest-00.html
java
thnks Jaime,this seems very
thnks Jaime,
this seems very helpful. will let you know if its works out for me.
Surendra
91
