Multiple NM / AIM CUE modules
Hi all,
can i use AIM-CUE module along with 1 NM-CUE module?
Actually i have a customer which is using 5 Auto-Attendants for their 5 different divisions ..... since the company is growing, they want few more Auto-Attendants.
Now the problem is that.. i can't configure 6 Auto-Attendants neither on AIM-Module nor NM-CUE module.
They are using 2851 box with 1 NM-CUE module.
Muddasir
1 REPLY
Bronze
Re: Multiple NM / AIM CUE modules
No you can't use AIM-CUE module along with 1 NM-CUE module in 2851 but multiple CUE modules can be installed in a ISR 3845 chassis. I recall that you can install up to 4 - NM and 2 - AIM modules.
111
