Multiple Outbound Caller ID on a SIP Trunk
We've got CUCM 8.6.2 and have a SIP trunk from our provider going through a CUBE.  Today everything is working well.  Because of a few ordering/design issues, we're getting ready to port one of our remote site's numbers to our SIP Trunk and then route them over the WAN.  Inbound calls won't be an issue but we'd like all the remote sites outbound calls to show their name and caller ID information.
Right now I have the name and caller ID specified on the trunk but I don't see anyway to have it change based on the origin of the call.  I've seen where you can go to the line level to define the caller ID but I rather do it somewhere in-between if it is possible.  I tried adding another trunk but it didn't like the same destination IP.   I don't have much expereince with SIP as this is our first trunk.
Thoughts?
Thanks!
Re: Multiple Outbound Caller ID on a SIP Trunk
Hi.
Do you mean caller id to send to provider or caller id of internal calls between sites?
Let me know.
regards
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
It is caller id and name sent to the provider.    Internal calls won't change and work as expected.
Thanks!
Calling name is defined at DN level, no way around that.
Calling number can be defined at DN, route list, route pattern or GW/trunk level.
Easiest way would be to just define the external phone number mask at each DN and check that option at the RP.
Otherwise you'd need to create separate RPs to modify calling info based on what each phone can reach via CSS/partitions.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
So... please share your cube config and calling info you want to send to the provider
Carlo
Just as an FYI, we're running IOS 15.1(2)T5.
What I'd like to see is something like this:
For all calls execpt extns 1100-1199 - Name: Company A, Number: 555-555-1234
For calls from extns 1100-1199 - Name: Company B, Number 111-111-1234
All the 1100-1199 extensions are in their own Device pool but we use local routing on the CUCM side.
I can't post the entire config but here are the revalant sections:
voice service voip
address-hiding
mode border-element
allow-connections sip to sip
no supplementary-service sip moved-temporarily
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface Loopback10
  bind media source-interface Loopback10
  error-passthru
  asserted-id pai
  early-offer forced
  midcall-signaling passthru
  privacy-policy passthru
  g729 annexb-all
voice class codec 4
codec preference 1 g711ulaw
codec preference 2 g729r8 bytes 30
codec preference 3 g726r32
voice class codec 1
voice class sip-profiles 1
request INVITE sdp-header Audio-Attribute modify "a=ptime:20" "a=ptime:30"
response ANY sdp-header Audio-Attribute modify "a=ptime:20" "a=ptime:30"
request REINVITE sdp-header Attribute modify "a=T38FaxFillBitRemoval:0" ""
voice class sip-profiles 2
response ANY sip-header Allow-Header modify "UPDATE," ""
dial-peer voice 1999 voip
description Outgoing voice / fax to SIP Provider
destination-pattern .T
session protocol sipv2
session target ipv4: (Provider IP)
voice-class codec 1
voice-class sip asserted-id pai
voice-class sip privacy-policy passthru
voice-class sip early-offer forced
voice-class sip profiles 1
dtmf-relay rtp-nte
fax-relay sg3-to-g3
no vad
dial-peer voice 732 voip
description incoming voice call from SIP
destination-pattern (Incoming Phone number pattern)
session target ipv4: (CUCM-IP)
incoming called-number (Incoming Phone number pattern)
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400 bytes 48
no vad
sip-ua
no remote-party-id
disable-early-media 180
retry invite 2
Hi.
Sorry for my late.
Now.. a solution could be:
- For calls from all extension except 1100-1199 create a partition OUT_COMP_A
- Create a CSS CSS_OUT_COMP_A
Create a route pattern 9.! and add a calling party transform mask 5555551234 and a prefix 1070
-Associate this CSS to all phones except 1100-1199
(If you are using local route group, the above steps are not necessary because you can add both calling party transform mask and prefix digit in the route list --->route group configuration page)
Repeat the same steps for phones from 1100 to 1199 changing calling party transform mask with 1111111234 and prefix digit into 1071
(we'll use prefix digit to differentiate outgoing dilapeer on cube config)
Now on cube config add 2 sip-profiles where we modify the calling name
voice translation-rule 10  (with this rule we remove the prefix added on route pattern on CUCM)
rule 1 /^1070/ //
rule 2 /^1071/ //
voice translation-profile strip-prefix
translate called 10
voice class sip-profile 100 (this will be for company A)
request INVITE sip-header Remote-Party-ID modify "\"(.*)\" <>" "\"Company A\" <>"
request INVITE sip-header From modify "\"(.*)\" <>" "\"Company A\" <>"
voice class sip-profile 101(this will be for company B)
request INVITE sip-header Remote-Party-ID modify "\"(.*)\" <>" "\"Company B\" <>"
request INVITE sip-header From modify "\"(.*)\" <>" "\"Company B\" <>"
Now create 2 dial peers matching outgoing prefix
dial-peer voice 1070 voip
translation-profile outgoing strip-prefix
voice-class codec 1
voice-class sip profiles 100
dtmf-relay rtp-nte
no vad
dial-peer voice 1071 voip
voice-class codec 1
voice-class sip profiles 101
dtmf-relay rtp-nte
no vad
Carlo
Hi Carlo,
That was extremly helpful, thank you for the response!!!
I had one question, on the dial-peers, there's something missing to match properly isnt there?  We'd need something like:
incoming called-number 1071.T
voice-class codec 1
dtmf-relay rtp-nte
no vad
Is that correct?
Hi.
Sorry i missed that :)
Yes on DP 1070 configure destination-pattern 1070T and on DP 1071 configure destination-pattern 1071T
Sorry again :)
Carlo
Great, thanks!  I've got a couple weeks before this needs to go into production so I'll let you know how it works out after that.
Your help is much appreciated!!!
2833
