Multiple PRI lines on 3825
I've got a 3825 router running Cisco IOS 12.4(24)T connected to the pbx via PRI line. Hardware is VWIC2-1MFT-T1/E1 and PVDM2-64 onboard. This PRI line tends to be overloaded so we want to add another VWIC2-1MFT-T1/E1 card and PVDM2-64 resource to the gateway and configure trunk group on the pbx side. The question is whethter it is possible to group this E1s into one logical trunk group on the router and to reference this grouping in the dial-peers? (or should I use dedicated devices such as cisco universal gateways).
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Yes, it is perfectly possible.
Green
Re: Multiple PRI lines on 3825
Yes what you describe is  the way to implement trunk groups etc.
As far as DSP resources are concerned to run 2 PRI/E1s you would need at leat a PVDM2-64 or the equivelant like 2 x PVDM2-32 etc
The OLD DSP calculator for a 3825 is available at http://www.cisco.com/cgi-bin/Support/DSP/cisco_prodsel.pl
You will need CCO login credentials
The new DSP calculator includinfgthe ISR-G2 range like 20xx & 39xx is on
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
Alex
Regards, Alex. Please rate useful posts.
Thank you for your reply. Could not find any cisco doc with configuration example.
As I can understand I'll need to
1) Create global trunk group
trunk-group PBX
2) Assign interfaces to trunk group
    interface  serial 0/0/0:15
    trunk group PBX
    interface serial 0/1/0:15
    trunk group PBX
3) Reference this group in the dial-peer
dial-peer voice 9 pots
dest-pattern 9......
trunk-group PBX
What about the DSP resources? Do I need to configure  them in some special way or it will be enough to physically insert the second module and it will work with my trunk-group automatically?
Green
Alex
I use G729a and my present DSP module can only handle 30 calls. I want to add another PVDM2-64 to increase the number of simultaneous calls to 60. (The DSP calculator suggest to add one PVDM2-48 + one PVDM2-8 though. This is unclear to me because for 30 G729a calls it suggests one PVDM2-64. So if I need to double the number of calls my understanding was that another PVDM2-64 is required)
Anyway, I've never used more than one DSP module so my question is whether I need to configure them in some special way or should they wok with my trunk group automatically?
Hall of Fame Super Silver
each g729 call will use 2 Pvdm channels, so simply do the multiplication.
528
