multiple PRI lines to gateway
All, Need some help on this please. Im in the process of setting up a new UCM with infrastructure to go with it. Customer is getting a 3825 gateway, and 4 PRI lines will be coming into it. Im planning on using MGCP to UCM, but if UCM server fails, Id like for phones to register to the gateway and still be able to make calls out/in. Im thinking about the dial-peers and how they should be setup. Would I be using 1 dial-peer to configure so that calls going out would be distributed among the PRI lines? OR, would I need to know what DIDs come in on each PRI so that I can do dial-peers accordingly to that specific PRI line (i.e. 1234 comes in on PRI #1, and 6789 comes in on PRI #2. Would the dial-peers have to reflect that in particular?)
1 ACCEPTED SOLUTION
Re: multiple PRI lines to gateway
Your incoming dial peers would not need to reflect which DID comes in on which PRI. Outgoing dial peers would be something like:
dial-peer voice 1 pots
destination pattern 9[2-9]......
port 0/0/0
dial-peer voice 2 pots
port 0/0/1
preference 1
dial-peer voice 3 pots
port 0/0/2
preference 2
dial-peer voice 4 pots
port 0/0/3
preference 3
Hope this helps.
Brandon
port 0/0/0
port 0/0/1
preference 1
port 0/0/2
preference 2
port 0/0/3
preference 3
Hope this helps.
Brandon
Thanks. I appreciate the help.
Do you think I should add the "forward-digits 7" command in each of these?
Yes, you would need the forward-digits 7 command in this case. For other destination patterns, you would obviously need to forward a different number of digits, such as:
91[2-9..[2-9]...... - forward-digits 11
911 - forward-digits 3
9911 - forward-digits 3
9011T - prefix 011
Hope this helps.
Brandon
Hall of Fame Super Gold
hi,
why not using trunk group for a easier configuration:
int serial x/y
trunk-group mypri
dial-peer voice 999 pots
destination-pattern ...
trunkgroup mypri
that's all!
The withing the trunk group you can do additional configurations, etc.
157
