Multiple PRIs - hunt
we have 3 PRIs, al connect to the same gateway(3825). We need to set up the next incoming or outgoing call will go the 2nd PRI if the first one is full. Should we configure that in CallManager, if so, how to do that? or we just need to call the Telco to set it up?
To make the 1st PRI full, someone in the forum said use the 1st phone to 2nd phone, hold it, and use the 2nd phone to cal the first one, etc, but how can I achieve that if every phone only has two line assigned?
1 REPLY
Re: Multiple PRIs - hunt
You can only configure outbound failover, your telco should take care of inbound
Read this to understand what to do
Call Routing in Unified CM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/dialplan.html#wp1044129
java
if this helps, please rate
java
www.cisco.com/go/pdi
135
