Multiple Protocol Type E1 Callmanager 6.1(1)
I will have a Callmanager 6.1(1) voice gateway connecting to two traditional PBXs over E1s using MGCP. One of the E1 will be configured as QSIG, and the other one as Net-5. Is this possible? What switch type will I configure on the global configuration?
Hall of Fame Super Gold
Re: Multiple Protocol Type E1 Callmanager 6.1(1)
Yes, it's possible. CCM supports both switch types.
Thanks for the response.
As the single gateway will be connecting to two PABXs, each with different protocol type, QSIG and Net-5.
Which protocol type do I configure on the global config, QSIG or Net-5?
I assume that I would be able to configure the first E1 as QSIG and the other E1 as Net-5 on the Callamanager 6.1?
CCM provides only global config for ISDN Switch type. You need to specify different switch-type on both isdn interfaces on the router manually which will override the global switch-type configuration pushed by the ccm to gw.
thanks,
inner_silence
Hi, with MGCP the switch type configured on the GW doesn't matter, you configure the proper type in the CCM.
In case different switch-types are required on same MGCP GW, we can configure no ccm-config and configure different switch-types on idn interfaces manually.
inner_silence
With MGCP, it doesn't matter what switchtype is configured. All is controlled by the sofwswitch.
In reality, being qsig a pri derivate (net5 being the reference), it really doesn't matter what is set, as long CCM know how to use specific qsig stuff that can be present on a circuit but not on the other.
137
