12-14-2011 04:36 AM - edited 03-16-2019 08:32 AM
Just in case we have one pub and multiple subscribers(2), and i am in the process to add a third subscriber. We have a group of IP Phones that should register as a priority with subscriber#3, while other group should be registered as a priority with Subscriber 2,.. then i have to create multiple call manager groups. Right?
I create a call manager group#3 for example where i put subsciber3 as a first priority, and i create a devicePool # 3 to assign this call manager group#3 to it.
And on the phone i select the devicePool#3.
I reset the phone and i still find that the ip address of subscriber 2 still the ip placed under option 21 in the network configuration settings of the phone which is call manager 1.
Is there any other thing to check concerning this prioritization of the phone registration with the correspondent call manager subscriber?
regards,
Solved! Go to Solution.
12-14-2011 07:14 AM
You will have to restart " Cisco tftp" service. It will resolve the issue.
If it is production environment, Please make sure you do it during off hrs.
Ronak Patel
12-14-2011 06:27 AM
Hi.
Version of cucm and IP phone models.
Let us know
Carlo
12-14-2011 06:34 AM
hello,
CUCm Version 6
IP Phones models are several, but the one testing with currently is 7960
regards,
12-14-2011 07:10 AM
Under the CUCM admin page, check 'Device' and 'Phones' each phone should say 'Registered with X.X.X.X' are the phones showing as being registered with the wrong server here?
I guess you have created a new Device Pool and added the new CM group to that Device Pool then moved the phones in question into the new DP??
Matty
12-16-2011 03:40 AM
the ccm sub 3 i am talking about is right now down for an upgrade purpose.
so on that page the phone indicates that the phone is registered with ccm sub 2,
but on the phone setting itslef, if i click on the button settings/ netowrk configuration i found that call manager 1 is the IP Address of CCM sub2 indicating active while it should be (as i guess) the ip address of CCM sub 3 indicating standby or down or something like that.
yes i did
created a new Device Pool and added the new CM group to that Device Pool then moved the phones in question into the new DP.
thanks mmoulson
12-14-2011 07:14 AM
Ronak Patel
12-16-2011 03:34 AM
thanks ronak,
but i didnt get your point.
in my case the tftp service is runnin on Publisher only and it will still running under the pub, but the phone registration should be registered with ccm sub 3 as a priority when available.
i think this should be done on the ccm group then the device pool assigned to this phone.
reseting the tftp service will do what in my case?
i still even when reseting the phone finding
ccm 1 is IP of sub 2
while it should be in my case the ip of sub 3
please clarify your point
12-16-2011 03:46 AM
The Cisco TFTP service builds and serves files consistent with the trivial file transfer protocol, which is a simplified version of the File Transfer Protocol (FTP). Cisco TFTP builds configuration files and serves embedded component executables, ringer files, and device configuration files.
So just in case if the config files are not updated, you may have to restart the tftp services.
Also you will have to erase configuration of the ip phones , the ip phones some time do not take new values of CCM1 and CCM2 etc...
Ronak Patel
12-16-2011 03:52 AM
how may i erase the configuration of the ip phones?
manually? or just reseting the tftp service will do so?
12-16-2011 03:58 AM
erasing configuraiton of Ip phone is to be done manually.
Follow below procedure for 7960 phones, It would be more or less similar for other phones.
Ronak Patel
12-16-2011 04:09 AM
when i Highlight Erase Configuration
when there is no option for "yes"
no soft key for yes
why?
12-16-2011 04:39 AM
Try typing
**# when you are looking at the menus
A little padlock at the top of the screen should OPEN
Alex
12-16-2011 04:46 AM
thanks acambell,
i erased the config still same isuue.
so let me ask my question in a different way,
on a IP phone settings / network configuration/ "call manager 1" option represents what?
the first call manager on the ccm group? or the ccm where the phone is registered? or a random ip of the ccm cluster?
and thank you for your reply
12-16-2011 05:12 AM
Call Manager 1 = Your Primary Call Processor (1st Priority)
Call Manager 2 = Your Secondary Call Processor (2nd Priority)
Call Manager 3 = Your 2nd/Secondary Call Processor (3rd Priority)
and so on
Yor last priority may be your SRST if you use it.
The 1 st priority will be the top CM in your CM group selected by your device pool.
You phone will always be registered with your 1st priority until there is a failure of that CM.
Alex
12-16-2011 06:58 AM
If resetting the phone gets the same config it means CUCM is just giving again the same info, go to the TFTP service parameters, click advanced and look for a parameter which should be build selective, change to build all files, restart TFTP and then reset the phone.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
