Multiple vg248 Installation
tohoken
All, I have been tasked with installing 3 vg248's in our CCM 4.1.3 environment and was wondering if there are any install guide out there that can help? I have no idea how to chain the 3 together or how to configure them once they are chained. Do they appear as 1 device when chained, etc. Any help would be appreciated.
paolo bevilacqua
You cannot chain together the VG224 so will need to use an Ethernet switch. Also they will appears as separate devices to your CCM.
Ultimately you guide is the CCM administrator guide where it discuss VG series usage.
Rob Huffman
Hi Ken,
Just wanted to add a note to Paolo's good info. The VG248's are really great to install and they ship with an excellent step by step guide. Have a look at these docs that explain the Hardware and Software components of the install;
Installing the VG248
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/products_installation_guide_chapter09186a00800878f4.html
VG248 Software Configuration Guide v1.3
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/products_configuration_guide_chapter09186a008023514f.html
Hope this helps!
Rob
