Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Music file can't be processed (MOH)
I want to change the Music on hold (MOH) and for this reason I dropped the file in a special folder. The dropped file can't be processed. It did work a few times but this time the music file remains in the folder. I restarted the CallManager 4.1 but it didn't help either.
Any suggestions how to tackle this issue?
Thanks.
Re: Music file can't be processed (MOH)
May be you should check a service called Cisco MOH Audio Translator in your MoH server. Is it started or not ?
You can check it in Cisco Call Manager Serviceability, Tools -> Control Center.
Wiyandi
Dear Wiyandi,
I checked Cisco MOH Audio Translator a few times. I restarted the service but it didn't help either.
Thanks.
Just start this service:
Cisco IP Voice Media Streaming App
Watch the file disappear, you can stop the service when you're done. It's pretty processor extensive.
Good luck.
IPVMS has NOTHING to do with the MOH translation Ahmed, the one that needs to be running is the MOH Audio Translator as the other posts mention
are you dragging and dropping the files in the folder?
if so, do not do that.
copy or cut the file and then open the translator folder and paste it in there
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Green
Under DropMOHAudioSourceFilesHere folder check that CCMService account has FullControl rights if not assign it.
Please check the permissions on the file that is placed in the directory (right-click, properties-> security tab). If it was copied
from another location on the server, it will retain its old permissions. If the CCMService account does not have permission on
this file, it will not be able to access it.
You can un-check the "Allow inheritable permissions..." option, apply,
then re-check it. This should give the file the permssions from the directory.
Also gather MOH AudioTranslator traces
under CMS folder atXXXXXX.txt if above still doesnt help
Gogasca is exactly right. Normally when a MOH file does not disappear from the directory it's a permissions issue.
This has been asked before!
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40.2cbe4b8f/0#selected_message
157
