Music on hold CD-ROM
According to various CallManager design guides, you can obtain a separate Music on Hold CD-ROM from Cisco.
Any ideas where to actually get this from?
Hall of Fame Super Red
Re: Music on hold CD-ROM
Hi Michael,
When you install Cisco CallManager on your server, a default music on hold sample automatically installs for customer use. To increase your music on hold (MOH) selection, you may also install the Cisco CallManager Music On Hold Disk that **ships with your Cisco IP Telephony Applications Server, or you may download one of two following files via the web:
ciscocm-MusicOnHold, which is a set of wav files providing the entire music selection from the disk
ciscocm-MusicOnHoldSampler, which is a small set of files offering a sample of music available on the disk
** I just looked and these files can be found at the attached link with CCO Login (Right down towards the bottom of the page)**
http://www.cisco.com/cgi-bin/tablebuild.pl/callmgr-33
Hope this helps!
Rob
Please remember to rate helpful posts.....
Helps a great deal, many thanks for this.
Cheers
Mike
Any good 3rd party sites that have unlicensed music to use for MoH?
Thanks...
851
