Bronze
Music on Hold just for PSTN caller!!!
Hi all,
CCM 4.13
I dont think this can be done, but I want to verify with you guys.
1. extension 1111 calls extension 1112, if extension 1111 place on hold, we dont want any music being played.
2. PSTN calls DID extension 1111, when extension 1111 place on hold, PSTN caller should hear music.
If 4.13 doesnt have this feature, how about 6.1??
Ken
1 ACCEPTED SOLUTION
Re: Music on Hold just for PSTN caller!!!
Hi Ken,
If extension 1112 should not hear music, then assign them a MRGL that does not have access to the MOH resource. They'll hear tone on hold instead.
If the PSTN should hear music, then assign the gateway a MRGL that has access to the MOH resource.
Does this meet the requirement?
Michael.
Hi Ken,
Michael.
Bronze
Michael,
It does make sense to me... never thought about that.
I am going to try now.
Thanks millions
Ken
You're welcome Ken. Keep us posted!
Michael.
You can do this by distinguising your off-net and on-net calls. By using on-net MOH you can specify silence or tone on hold and when you have an off-net call you can then specify your MOH.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmfeat/fsmoh.html#wpxref59089
129
