Music On Hold UCM 6.x
Does anybody know how to download the MoH files that come with UCM 6.x (or any of the linux versions?)
Re: Music On Hold UCM 6.x
Shanky asked for the exact same thing yesterday:
Unified Communications Applications: MOH uploaded files in CM 6
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&topicID=.ee835d2&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd26aca
please search previous post using the Search NetPro function, that post is sitting in the Unified Communications Applications section if click on the link
java
if this helps, please rate
java
www.cisco.com/go/pdi
If I do "file get activelog mohprep" it only downloads the sample files, even those the LIST commands show the other ones. Theres a space in the MOH files i wonder if that makes a difference
201
