04-05-2007 12:26 PM - edited 03-14-2019 08:51 PM
Is there anyway to change the volume of MoH on CallManager?
Solved! Go to Solution.
04-05-2007 12:44 PM
Hi Chris,
Here is an excellent Cisco Tech Note, pay special attention to this excerpt;
"Changes to this parameter only affect audio files that are processed after the change occurs."
From this doc;
CallManager Music On Hold Volume Adjustment
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805997bc.shtml
Hope this helps!
Rob
04-05-2007 12:44 PM
Hi Chris,
From this doc;
Hope this helps!
Rob
06-12-2007 09:23 AM
I wonder how you can change the volume for music on hold when its running off the flash?
06-12-2007 09:26 AM
You will have to re-record the file with lower volume. I think you can use this tool called Audacity, you can download it for free to tune the volume. Just google it.
