Community Member
Music on hold
Dear all,
Can i disable music on hold per extension, or must canceled by the CCM at all extensions global.
How to be done at both cases.
Note: i use CCM 4.2(3)
Everyone's tags (1)
Re: Music on hold
If you don't want someone to hear MOH remove the MOH server from their MRGL.
Create a MRGL with no MOH for those users and assign them that MRGL.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
Re: Music on hold
Thx a lot but, how can i do so
Re: Music on hold
Create two MRGLs, one with MOH server and one without MOH server
It's as simple as that
java
java
327
