Community Member
Mute calls get disconnected
Hello, does anybody ever meet the following scenario:
=> Call get disconnected when both calling and called parties place the call in a mute state (for 2 minutes)
Calling phone is 7960 phone on CallManager 4.1(3) and called party is any phones on the PSTN. PSTN is connected with 2821 MGCP gateway.
In the deb isdn q931, we can see:
ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x888D
Cause i = 0x80A9 - Temporary failure
I am looking at a isdn timer problem or a call inactivity detection...
Any idea ?
Thanks a lot.
1 REPLY
Bronze
Re: Mute calls get disconnected
This issue is releated to rtcp timout:
Disable RTCP timer in MGCP. Using global config
mgcp-mrp-4(config)#no mgcp timer receive-rtcp
CSCdv05532
175
