Dear ALL ;
I am facing the following situation , your help is highly appreciated.
I want to get 2 PRI-Groups on the same PRI and use MGCP as CUCM will control it. The scenario is as following :
1st PRI-Group is for incoming calls ONLY from PSTN , it should use timeslots 1-11
2nd PRI-Group is for outgoing calls ONLY from PSTN, it should use timeslots 20-30
How is the possibility to implement that solution on CUCM 6.x.? I know that there is a possibility for only one PRI-group fraction-based feature using MGCP , and there is a solution using H323 ; but I want that kind of solution as CUCM will control some other FXOs/FXSs for the ease of use need.
