mva with E1 R2
hello I need to know if anyone can work the MVA Mobile voice access con E1 R2 modific?
Hall of Fame Super Gold
Re: mva with E1 R2
Your question cannot be understood, say that again other words.
Re: mva with E1 R2
Hello I have the next Interactions and Restrictions
"Mobile Connect features are not supported for T1 CAS, FXO, FXS and BRI."
But I have E1 R2 , can I configured this feature mva with E1 R2?
Re: mva with E1 R2
Check if you can have Mobile Connect working with the GW in H.323 mode. If it can, it will not even know you've E1 R2.
Re: mva with E1 R2
Cisco Does Not support Mobile Connect over T1-CAS, FXO and E1 R2. as per cisco CUCM 7.x SRND:
"Mobile Voice Access and Enterprise Feature Access are supported for all incoming PSTN devices capable of sending DTMF digits. Cisco Unified IP Phone support for these features is the same as for Mobile Connect "
(i did not test MVA over E1 R2 , i tested Mobile Connect and it was not working)
258
