Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
MWI and CUE Issues
See attachment please.
Any pointers on what I need to trace and how to, because I am a newee to IP Telephony.
I have just started to prepare for CCVP last week.
Re: MWI and CUE Issues
SHOW TECH and SHOW LOG Attached.
Where so I start troubleshooting?
I have a few questions, do you know what extension numbers are having issues with MWI?
Are they the same extension numbers each time?
The Cisco bug tool highlights several issues regarding SIP and MWI, but the one that stands out is CSCsd56683 - MWI will not be sent if phone is Deregistered.
From your 'sh tech' some phones are unregistering, are these the same phones that are having MWI problems?
The following 7961 phone has unregistered.
Feb 26 07:10:16.949 EST: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-71:SEP0017E08C6A7D
From your config, it would seem that this same 7961 phone is configured with voicemail - using SIP MWI.
ephone-dn 71 dual-line
number 671
label 671
description 99304671
name Workstation 21
call-forward busy 900
call-forward noan 900 timeout 10
corlist incoming STDCalls
mwi sip
Why have you elected to use SIP for MWI why not use SCCP?
From memory, we had issues getting it working with SCCP due to the 2
router setup. So customehad to use SIP to overcome the issues with the
phones registering in failover mode.
364
