MWI AND FXS
HI all,
          I am running CUE 2.3 and CME 4.0.3, I got the voicemail working(leave and retrieve voicemail);however, when a suscriber leaves a message CUE does not send a message waiting indicator to the phone to notify the user. Of course I do have two ephone-dns with mwi on and off.
In the same CME router, I also have a phone connected to the FXS port which i want to enable voicemail for. Cisco online docs says that CUE is able to assign mailbox for FXS port, but they do not show how.
Jean
1 REPLY
Hall of Fame Super Gold
Re: MWI AND FXS
1 - something is not configured correctly. I recommend "unsolicited notifiy", works well and simpler configuration.
2 - you need to configure FXS port in SCCP mode.
330
