MWI CME/UNITY EXPRESS ISSUE
I'm having some problems with mwi.  I have a router 2921 working as CME with Version 8.1.  It has a ISM-SRE-300-K9 for the Uity Express.  The phones i'm
using are 7970 and 7940.   The problem i'm having is that when somebody call and leave a voice message, the mwi ligth doesn't turn on.
Here is part of the configuracion i have for the MWI.
CME CONFIG
ephone-dn  61
description FOR MWI-ON
number 0777.... no-reg primary
mwi on
ephone-dn  62
description FOR MWI-OFF
number 0888.... no-reg primary
mwi off
dial-peer voice 9998 voip
description TO MWI-ON
incoming called-number 0777....
codec g711ulaw
no vad
dial-peer voice 9999 voip
incoming called-number 0888....
codec g711ulaw
no vad
Description:                            ciscomwiapplication
Application type:                       aa
Script:                                 setmwi.aef
ID number:                              0
Enabled:                                yes
Maximum number of sessions:             10
CallControlGroupID:                     0
strMWI_OFF_DN:                          0888
strMWI_ON_DN:                           0777
I'M NOT SURE ABOUT THIESE COMMANDS (is something i saw on internet)
codec g711ulaw
no vad
codec g711ulaw
no vad
UNITY EXPRESS CONFIG
Script:                                 setmwi.aef
ID number:                              0
Enabled:                                yes
strMWI_OFF_DN:                          0888
strMWI_ON_DN:                           0777
Can somebody tell me what i'm missing?
I have to do an exta configuration on the UNITITY EXPRESS ?
Thanks for your help.
Hall of Fame Super Gold
You are missing the mwi server config on CME.
Recommend to use unsolicited notify that works good and is simple to configure.
Re: MWI CME/UNITY EXPRESS ISSUE
Thanks for your response,
A question…
How do I set this. This way?
First in the CUE :
ccn subsystem sip
gateway address "CME-IPaddress"
mwi sip unsolicited
end subsystem
CME CONFIGURATION
Sip-ua
mwi-server ipv4:CUE-IPaddress expires 3600 port 5060 transport udp unsolicited
I can’t use sip-server ipv4: CUE-IPaddress, because I’m already using a sip-server for a SIP-TRUNK for registering to a SP SIP-PROXY.
If ip put this command doesn’t affect the SIP-TRUNK?
Regards.
Daniel Fulgencio
IP Networks Engineer
Telefónica Empresas
Una compañía de la Multinacional Española Telefónica
PO Box 70325
San Juan, PR 00936-8325
Tel: +1 787-774-5097
Cell: +1 787-424-0455
Email: daniel.fulgencio@telefonica.com
Typically I would use the CUE GUI to set the MWI parameters. The follwing document contains a MWI section on page 153.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel8_6/online_help/admin/GUI_PDF/gui_pdf.pdf
This was my last CUE MWI config piece tho.
ccn application cisco
application
description "ciscomwiapplication"
enabled
maxsessions 8
script "setmwi.aef"
parameter "CallControlGroupID" "0"
parameter "strMWI_OFF_DN" "7099"
parameter "strMWI_ON_DN" "7098"
end application
CME Config
ephone-dn  53
number 7098....
mwi on
ephone-dn  54
number 7099....
mwi off
Hi Dave,
I’ve done this configuration, which i had before configured in the CME. The problem I see is that when I go to the CUE-GUI and select MWI SETTING
It tells me that it doesn’t see any MWI numbers from the CME. I try to synchronize but I get an error.
Daniel Fulgencio
Telefónica Empresas
PO Box 70325
As mentioned before. With unsolicited notify, you don't need any mwi numbers.
Hi Paolo,
I’ve already configured unsolicited but still no working. Here is the configuration:
Sip-ua
mwi-server ipv4:10.234.144.254 expires 3600 port 5060 transport udp unsolicited
ephone-dn 6 dual-line
number xxxx
mwi sip
CUE:
In the CUE i selected unsolicited form MWI setting.
Is there anything I’m missing?
regards
Daniel Fulgencio
Telefónica Empresas
PO Box 70325
Hello Daniel,
Follow this guide
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a008037f2a9.shtml
You dont need the dial-peers to the MWI Numbers.
One more thing, when you call a extension XX to extension YY and you leave a message does the mwi turn on?
Or the problem is just when a external caller try to leave a message to an extension?
Hi Leonardo,
sorry for the late response.  I'm been out of office.
Yes i already tested callinf from another extension inside de CME.  But sitll doesn't work.
Right now  i'm using outcalling mode.  I've used the three mode but still nothing.  So i return to
the outcalling mode.  When i dialed the number i'm using fro MWI-ON o OFF pluss extension number
the light gets on-off.
But when i make a call form in or outside i can leave the message but the lights doesn't turn on-off.
regards.
3440
