Community Member
mwi indicator on wrong dn/line with CUE/CUCME
my CUE/CUCME MWI integration does not work as expected.
After recording a voicemail the CUE system sends an SIP MWI NOTIFY to the CUCME and the red envelope symbol gets activated on the wrong line number (in my case dn 1 instead of dn 2) - phone is 9971. Resetting the CUE and configuring it form scratch didn't help.
Somehow the whole 9971 integration seams a little bit unstable (call transfer does not work - no idea if there is anything in parallel).
Configuration and debug is attached
Thanks for any ideas.
Regards, Frank
******************Configuration*************************
version 15.2
boot-start-marker
boot-end-marker
no logging buffered
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
network-clock-participate wic 1
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip dhcp relay information trust-all
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp pool phone
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 217.0.43.97 217.0.43.113
option 150 ip 10.10.10.1
ip name-server 217.0.43.97
ip cef
no ipv6 cef
voice rtp send-recv
voice service voip
no ip address trusted authenticate
callmonitor
no callmonitor trace
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip handle-replaces
sip
  registrar server expires max 3600 min 180
  asymmetric payload full
  video screening
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g723r53
codec preference 4 g729r8
codec preference 5 g729br8
codec preference 6 g726r32
codec preference 7 g728
voice register global
mode cme
source-address 10.10.10.1 port 5060
max-dn 10
max-pool 4
load 9971 sip9971.9-4-1-9
load ATA-187 ATA187.9-2-3-1
authenticate register
authenticate realm all
timezone 21
time-format 24
date-format D/M/Y
voicemail 999
tftp-path flash:
file text
create profile sync 0000420080667255
network-locale DE
user-locale DE
camera
video
overlap-signal
voice register dn  1
number 91
allow watch
no-reg
mwi
voice register dn  2
number 90
call-forward b2bua noan 999 timeout 20
allow watch
no-reg
mwi
voice register pool  1
registration-timer max 300 min 60
id mac 0008.3030.6AAA
feature-button 5 DnD
session-transport tcp
type 9971
number 1 dn 1
number 2 dn 2
dtmf-relay rtp-nte
voice-class codec 1
no vad
camera
video
no ip ftp passive
interface FastEthernet0/0
description ***ISP Provider***
ip address dhcp
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Integrated-Service-Engine0/0
ip unnumbered Vlan1
ip nat inside
service-module ip address 10.10.10.2 255.255.255.0
service-module ip default-gateway 10.10.10.1
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication aaa
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 87.186.225.92 254
ip route 10.10.10.2 255.255.255.255 Integrated-Service-Engine0/0
access-list 1 permit 10.10.10.0 0.0.0.255
control-plane
mgcp profile default
dial-peer voice 20 voip
description **Mailbox**
destination-pattern 99.
session protocol sipv2
session target ipv4:10.10.10.2
voice-class codec 1
dtmf-relay rtp-nte
no vad
presence
presence call-list
sip-ua
credentials username ***number*** password ***password*** realm **realm**
authentication username ***user*** password ***password*** realm ***realm**
nat symmetric role active
nat symmetric check-media-src
no remote-party-id
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry notify 6
retry register 5
retry options 10
timers connect 100
timers notify 100
timers register 250
mwi-server ipv4:10.10.10.2 expires 3600 port 5060 transport udp
registrar 1 dns:**registrar** expires 3600
sip-server dns:**registrar**
connection-reuse
host-registrar
presence enable
telephony-service
no auto-reg-ephone
max-ephones 12
max-dn 30
ip source-address 10.10.10.1 port 2000
max-redirect 5
timeouts interdigit 2
url services http://10.10.10.2/voiceview/common/login.do
cnf-file location flash:
user-locale U1 load CME-locale-de_DE-German-8.8.2.5.tar
load 7925 CP7925G-1.4.4.3.LOADS
time-zone 23
time-format 24
date-format dd-mm-yy
voicemail 999
max-conferences 4 gain -6
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
access-class 102 in
privilege level 15
transport input all
transport output all
line vty 5 15
access-class 101 in
exec-timeout 30 0
privilege level 15
transport input all
end
********************************** debug ccsip messages **************************************
NOTIFY sip:90@10.10.10.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.10.2:5060;branch=z9hG4bKSLiy2tv6m.ZgKxUe8Y2eLQ~~144
Max-Forwards: 70
To: <sip:90@10.10.10.1>;tag=A7BEBF8-B74
Call-ID: BDAE6318-4BB311E3-8B318DCC-E4968F82@10.10.10.1
CSeq: 5 NOTIFY
Content-Length: 109
Contact: sip:90@10.10.10.2
Event: message-summary
Allow-Events: refer
Allow-Events: message-summary
Allow-Events: telephone-event
Subscription-State: active
Content-Type: application/simple-message-summary
Messages-Waiting: yes
Message-Account: sip:90@10.10.10.2
Voice-Message: 1/0 (0/0)
Fax-Message: 0/0 (0/0)
*Nov 13 18:08:29.743: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 13 Nov 2013 18:08:29 GMT
CSeq: 5 NOTIFY
Content-Length: 0
*Nov 13 18:08:29.747: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:90@10.10.10.12:52895;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.10.10.1:5060;branch=z9hG4bK250B21A8
To: <sip:90@10.10.10.12>
Call-ID: 6F329427-4BC511E3-8C258DCC-E4968F82@10.10.10.1
CSeq: 101 NOTIFY
Max-Forwards: 70
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M5
Contact: <sip:90@10.10.10.1:5060;transport=tcp>
Content-Length: 23
*Nov 13 18:08:29.751: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Wed, 13 Nov 2013 18:08:31 GMT
CSeq: 101 NOTIFY
Content-Length: 0
152
