MWI indicator voice messages not working
Hello
I  have trouble configuring the CME / CUE because the LED display, voice  mail does not work properly when the user receives messages (the lamp  does not light)
Here I leave the sh run of the CME / CUE.
Thank you for your help.
Hall of Fame Super Red
Re: MWI indicator voice messages not working
Hi Nati,
Can you please try adding the (3 dots ...which should equal the extension length in your dial plan)
ephone-dn  198
number 303...
mwi on
ephone-dn  199
number 304...
mwi off
The number of dots (...) should be equal to the extension length being used
Have a look at this excellent Troubleshooting doc;
Troubleshooting Unity Express Message Waiting Indication (MWI) Problems
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a008027fa9f.shtml
Hope this helps!
Rob
Hi Rob,
You were right, recheck the document and found the solution to my fault and I was here:
.-Make sure that mwi sip outcall is configured under the ccnsubsystem sip command.
Saludos,
Nati.
El mensaje fue editado por: nataliabello
458
