Community Member
MWI issue with CME and CUE running on seperate routers
I cannot get the MWI lights to work on the phones.
here is the dial peer on the CME router
dial-peer voice 1001 voip
destination-pattern 900.....
session target ipv4:172.22.12.250
codec g711ulaw
no vad
Here are the ephones
ephone-dn 190
number 9000....
mwi on
ephone-dn 191
number 9001....
mwi off
Here is part of the config on the CUE router
codec g711ulaw
no vad
telephony-service
load 7910 P00403020214
load 7960-7940 P00303020214
load ATA ATA030100SCCP040211A.zup
max-ephones 48
max-dn 192
ip source-address 172.16.11.254 port 2000
create cnf-files version-stamp 7960 Aug 06 2007 11:47:32
max-conferences 8
timeouts interdigit 5
moh music-on-hold.au
web admin system name admin password want0p3n
dn-webedit
time-webedit
ephone-dn 190
number 9000....
mwi on
ephone-dn 191
number 9001....
mwi off
also ccn application
tllcvmrouter> sh ccn application
Description: ciscomwiapplication
Script: setmwi.aef
ID number: 0
Enabled: yes
Maximum number of sessions: 8
CallControlGroupID: 0
strMWI_OFF_DN: 9001
strMWI_ON_DN: 9000
If i dial 90002765 the phone extention the system lights the phone. If I dial 90012765 theextention it unlights the phone.
I also have SMTP forwarding turned on and VM's are getting to the VM system as well as email. I just cannot get the MWI to work.
Todd
Re: MWI issue with CME and CUE running on seperate routers
Hi:
I think the communication between CME and CUE is SIP based. So i guess you would have to include under your dial-peers
session protocol sipv2
dtmf-relay sip-notify
codec g711ulaw
And also session target IP address has to IP Address of CUE.
Community Member
I had that in there in the past with no luck. I added again and still no light. As for the session target should it be the router IP or the CUE module IP?
Community Member
IP address should be the CUE module --
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/integration/unity_exp/configuration/guide/cue_cme1.html#wp1112746
SUMMARY STEPS
1. dial-peer voice tag voip
2. destination-pattern [+] string [T]
3. session protocol sipv2
4. session target ipv4:destination-pattern
5. dtmf-relay sip-notify
6. no vad
7. exit
destination-pattern-IP address of the dial peer that is to receive calls. Enter the IP address of the Cisco Unity Express module.
Community Member
also check sip-gateway in CLI config of CUE..
Should CUE be accessable from both routers? Or just from CCME? Refraised; is CUE-router also VOIP-enabled besides the dialpeer to CUE?
Community Member
Hi Todd,
I thought I'd come across this before. Take a look at this thread, it may be of use to you:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=General&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cbf180d/4#selected_message
Cheers,
-James.
Please rate helpful posts...
Community Member
Thanks in advance to everyone
I still cannot get the VM light to light up. I can dialing the MWI number 8000 and off dialing 8001. Here is the configs from both (with some info removed).
This is the CCME router
isdn switch-type primary-ni
voice call carrier capacity active
voice rtp send-recv
voice service voip
h323
sip
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 13-24
gw-accounting syslog
interface Serial1/0:23
no ip address
no ip redirects
no ip unreachables
no logging event link-status
isdn incoming-voice voice
no cdp enable
router eigrp 100
network x.x.0.0
auto-summary
ip classless
ip http server
ip http path flash
control-plane
voice-port 1/0:23
dial-peer voice 100 pots
description inbound and outbound to PSTN
destination-pattern 9.T
direct-inward-dial
port 1/0:23
dial-peer voice 8991 voip
description CUE Voice Mail System
destination-pattern 8991
session target ipv4:x.22.12.250
codec g711ulaw
no vad
dial-peer voice 8010 voip
description AtuoAttendent_recoreded message
destination-pattern 8010
codec g711ulaw
no vad
dial-peer voice 8011 voip
description AutoAttendent
destination-pattern 8011
codec g711ulaw
no vad
dial-peer voice 8000 voip
destination-pattern 8000....
dial-peer voice 8001 voip
destination-pattern 8001....
no vad
gateway
timer receive-rtp 1200
sip-ua
mwi-server dns:voicemail expires 3600 port 5060 transport udp unsolicited
telephony-service
load 7960-7940 P00308000700
max-ephones 52
max-dn 200
ip source-address x.16.11.254 port 2000
caller-id block code *67
timeouts interdigit 3
timeouts ringing 30
system message Welcome Todd
url services http://x.16.11.253/voiceview/common/login.do
url authentication http://x.16.11.253/voiceview/authentication/authenticate.do
time-zone 8
create cnf-files version-stamp 7960 Sep 12 2007 11:47:42
voicemail 8991
mwi sip-server x.22.12.250 transport udp port 5060 reg-e164
mwi expires 86400
max-conferences 8 gain -6
call-forward pattern .T
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 8...
transfer-pattern 111.
login timeout 600 clear 01:00
ephone-dn 180
number 7999
ephone-dn 190
number 8000.... secondary 8001....
mwi on-off
This is the CUE router
voice service voip
h323
sip
interface Loopback0
no ip address
interface FastEthernet0/0
ip address x.16.11.253 255.255.255.0
interface Service-Engine1/0
ip address x.22.12.254 255.255.255.0
ip route-cache flow
service-module ip address x.22.12.250 255.255.255.0
service-module ip default-gateway x.22.12.254
ip route x.22.12.250 255.255.255.255 Service-Engine1/0
ip http server
dial-peer cor custom
telephony-service
max-ephones 48
max-dn 192
ccn application ciscomwiapplication
description "ciscomwiapplication"
enabled
maxsessions 8
script "setmwi.aef"
parameter "CallControlGroupID" "0"
parameter "strMWI_OFF_DN" "8001"
parameter "strMWI_ON_DN" "8000"
end application
Todd
Community Member
Not sure if you got this working yet but I have the same situation at one of my locations, so where the CUE is you need to build out two VOIP dial peers this is how I have mine working, I have 5 digit dialing and my numbers are in a range at the other site hope this helps.
dial-peer voice 3765 voip
description MWI To Logistics
destination-pattern 80003765.
session target ipv4:10.3.204.1
codec g711ulaw
no vad
dial-peer voice 3766 voip
destination-pattern 80013765.
codec g711ulaw
no vad
304
