MWI not working......
Hi All,
My customer has recently setup a new CUE with the existing CME.  Everything works and users can retreive voicemails except MWI.
I am attaching the configuration..........
Thanx in advance......
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Rupesh,
From your original config that you had attached I would have tried;
ephone-dn  50
number 2600...
mwi on
ephone-dn  60
number 2601...
mwi off
Cheers!
Rob
"Why do the best things always disappear "
- The Band
Silver
     I would make sure that the Partition being used for the MWI devices are in the correct Calling Search Space that the voicemail ports are using as well.
Tony
Please rate helpful posts!
Tony
Hi Rupesh,
One thing to check is that the number of dots(.)
after these (below) is equal to your extension length. With the config
below you would need to be using 4-digit extensions due to
the 4 dots.
ephone-dn  50
number 2600....
mwi on
ephone-dn  60
number 2601....
mwi off
Cheers!
Rob
- The Band
Hi Rob,
I also check with following MWI:
ephone-dn  50
number 261...
mwi on
ephone-dn  60
number 262...
mwi off
but still problem is persist and this network i am not using any COR(Partition and CSS).
Hi Rupesh,
ephone-dn  50
number 2600...
mwi on
ephone-dn  60
number 2601...
mwi off
Cheers!
Rob
- The Band
Thanks Rob......
257
