Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
MWI Problem: Unity 7/Exchange 2007
on a new Unity 7 Deployment with Exchange 2007 - Used COBRAS to migrate from Unity 4.0.5 running on an old ICS7750 - New Domain on the 2007 Server. This is a Unified Messaging deployment.
When the caller leaves a VM, the MWI lights on the users phone, but the instant Outlook receives the message, the MWI light goes off. The message is not marked as read, and there are no rules directing it to another folder. Even if you right click the message and mark as unread, nothing changes and the MWI light does not come on.
Does anybody have experience with this issue?
1 ACCEPTED SOLUTION
Re: MWI Problem: Unity 7/Exchange 2007
What happens if Outlook is not running on the user's desktop?  Does the MWI still get turned off in that scenario?  If so, then something in Outlook is marking the message as read.  Maybe they have the preview pane loaded?  First, see if it is coming from the client (i.e. Outlook).
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
HTH.
Bill
I also faced the same problem. But I found that this is normal behaviour of the unity and exchange or you can say the this is how it works. If someone leaves the voicemail and if the voicemail is on the mail server then you can see the MWI on IP Phone. Once you downloads the mails from your mail server to your local PC mailbox, MWI becomes off. To better understand this:
1. Stop mail replication on your local machine
2. login to your webmail
3. Leave the voicemail
4. Mark the voicemail message read (MWI becomes off)
5. Mark the voicemail message unread (MWI becomes on)
Thanks & Regards,
Vaijanath
This was the problem - the user had a message rule turned on for the inbox to move to a local folder
313
