MWI SIP NOTIFY sent to router, failing to light up CME phone
well the story goes like this. I downloaded the new exchange server from microsoft just to test out since in this version (2010) MWI is now supported. My VOIP platform is a 2811 running c2800nm-ipvoice-mz.124-24.T.bin & CME 7.1 & my phones are 7971GEs. My voicemail is located on the exchange server and is reached via a dial-peer.
dial-peer voice 4400 voip
destination-pattern 44..
session protocol sipv2
session target ipv4:10.10.10.11
session transport tcp
dtmf-relay rtp-nte
codec g711ulaw
no vad
When i use on of my phones and leave a voicemail i receive the voicemail in email and exchange sends a SIP notify, debug ccsip messages shows that it arrives on the router but then it can't find the extention to turn MWI on?
Jun 19 13:40:50.735: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:4445@10.10.10.2:5060;user=phone SIP/2.0
FROM: <sip:srvexch01.inquery.corp:5067;transport=Tcp;ms-opaque=454001ffb3eff339>;epid=F76A3455EB;tag=febcca39a8
TO: <sip:4445@10.10.10.2:5060;user=phone>
CSEQ: 2 NOTIFY
CALL-ID: b70eb54764c54d0d9e3b44ffb045cdd8
MAX-FORWARDS: 70
VIA: SIP/2.0/TCP 10.10.10.11:47953;branch=z9hG4bKa4b7b089
CONTACT: <sip:4445@10.10.10.2:5060;user=phone>
CONTENT-LENGTH: 98
EVENT: message-summary
SUBSCRIPTION-STATE: terminated
USER-AGENT: RTCC/3.1.0.0
CONTENT-TYPE: appl
ccme#ication/simple-message-summary
Messages-Waiting: yes
Message-Account: sip:4445@10.10.10.2:5060;user=phone
Voice-Message: 11/8
Jun 19 13:40:50.739: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 481 Call Leg/Transaction Does Not Exist
Date: Fri, 19 Jun 2009 13:40:50 GMT
From: <sip:srvexch01.inquery.corp:5067;transport=Tcp;ms-opaque=454001ffb3eff339>;epid=F76A3455EB;tag=febcca39a8
Content-Length: 0
To: <sip:4445@10.10.10.2:5060;user=phone>;tag=563880-1462
Call-ID: b70eb54764c54d0d9e3b44ffb045cdd8
Via: SIP/2.0/TCP 10.10.10.11:47953;branch=z9hG4bKa4b7b089
CSeq: 2 NOTIFY
I'm not really sure what is going on here, but the docs. that i have found point to a 481 if the voiceport is not enabled for MWI. since i don't have a voice-port FXO, T1, FSO i'm not sure if that applies.
an answer would be great, but if not some insight as to what i should be looking at next would be awesome!!
Hall of Fame Super Gold
Re: MWI SIP NOTIFY sent to router, failing to light up CME phone
Do you have mwi under ephone ? What is you global mwi settings ?
the current configuration that i have now is:
ccme#sh run
Building configuration...
Current configuration : 2593 bytes
! Last configuration change at 17:55:21 UTC Fri Jun 19 2009
! NVRAM config last updated at 15:21:06 UTC Fri Jun 19 2009
version 12.4
hostname ccme
boot-start-marker
boot-end-marker
logging message-counter syslog
enable password cisco
no aaa new-model
ip source-route
ip cef
ip name-server 10.10.10.10
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol cisco
sip
bind control source-interface FastEthernet0/0
bind media source-interface FastEthernet0/0
header-passing
!voice-card 0
archive
log config
hidekeys
ip address 10.10.10.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/2/0
no ip address
shutdown
no fair-queue
interface Async0/0/0
no ip address
encapsulation slip
ip forward-protocol nd
no ip http server
tftp-server flash:cnu70.8-4-1-23.sbn
tftp-server flash:cvm70sccp.8-4-1-23.sbn
tftp-server flash:dsp70.8-4-1-23.sbn
tftp-server flash:jar70sccp.8-4-1-23.sbn
tftp-server flash:music-on-hold.au
tftp-server flash:term70.default.loads
tftp-server flash:term71.default.loads
tftp-server flash:SCCP70.8-4-2S.loads
tftp-server flash:apps70.8-4-1-23.sbn
control-plane
!mgcp fax t38 ecm
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
mwi-server ipv4:10.10.10.11 expires 3600 port 5060 transport tcp unsolicited
telephony-service
max-ephones 5
max-dn 5
ip source-address 10.10.10.2 port 2000
load 7971 SCCP70.8-4-2S.loads
voicemail 4400
max-conferences 8 gain -6
moh music-on-hold.au
transfer-system full-consult
create cnf-files version-stamp 7960 Jun 19 2009 12:56:07
ephone-dn 1
number 4445
call-forward noan 4400 timeout 3
ephone-dn 2
number 4446
ephone 1
mac-address 0019.305D.41C8
type 7971
mwi-line 1
button 1:1
ephone 2
mac-address 000A.B79A.D5C0
button 1:2
line con 0
line aux 0
line 0/0/0
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
exec-timeout 0 0
password cisco
logging synchronous
login
scheduler allocate 20000 1000
end
ccme#
Sorry, wouldn't know what to suggest.
Basically since you're using a third-party VM you're on your own to make it work.
You could use this Perl Script in order to test to send a message to any Phone/IP Address:
#!/usr/bin/perl
use Socket;
my $phoneip = $ARGV[0];
SendSIPTo("$phoneip"); # IP of the phone
sub SendSIPTo{
$phone_ip = shift;
$MESG="NOTIFY sip:6001\@$phone_ip SIP/2.0
Via: SIP/2.0/UDP 10.252.36.96:5060;branch=z9hG4bK13579926;rport
To:
Contact:
Call-ID: 78f238ec7e8eeb414347cd4d46f37807\@10.0.1.23
CSeq: 102 NOTIFY
User-Agent: Asterisk PBX
Max-Forwards: 70
Event: message-summary
Content-Type: application/simple-message-summary
Content-Length: 90
Message-Account: sip:asterisk\@10.0.1.23
Voice-Message: 1/0 (0/0)";
$proto = getprotobyname('udp');
socket(SOCKET, PF_INET, SOCK_DGRAM, $proto) ;
$iaddr = inet_aton("0.0.0.0");
$paddr = sockaddr_in(5060, $iaddr);
bind(SOCKET, $paddr) ;
$port=5060;
$hisiaddr = inet_aton($phone_ip) ;
$hispaddr = sockaddr_in($port, $hisiaddr);
send(SOCKET, $MESG, 0,$hispaddr ) || warn "send $host $!\n";
You may have to download ActivePerl or simular and then just start the Perl script and add the IP address of the Phone via the command line.
thats a good idea. i have a question as to how that would work. the ip phones i have are SCCP and are registering with the cisco router, i was counting on the router to do the media translation from SIP to SCCP. is this the normal behavior and is the router suppose to be doing this that way?
the voicemail server in the debug output i attached above sends an unsolicited NOTIFY to the router and is it the responsibility of the router to perform the translation from SIP to SCCP since obviously SIP wouldn't be able to talk directly to the phone.
m.m
You understanding is right, perhaps something is wrong in the message, but without comparing with an e.g. CUE message, it's hard say what.
thats actually a pretty cool idea. i adapted the content of the script you gave me, thanks btw and a "debug ccsip messages" on the router shows that it arrives. the router throws no errors and everything appears to be formated correctly. the message should be turning on WMI for the extension 4445@. no luck. i'm leaning towards a misconfigured router at this point. does anything in my configuration stick out to you as wrong?
I have the similar problem with CME and Cisco Unity Connection!
I integrated CME and Unity Connection using SIP, everything works fine, but when I leave a message for dn 3002, the ephone does not show mwi on!
On CME I can see that message notify is sent to ext 3002, but the lamp is not turned on!
The extension 3002 is associated with CIPC (I also tried with 7912, but nothing), VM pilot number is 3600!
IOS version is flash:c2800nm-advipservicesk9-mz.124-22.T.bin!
In attachment you can find CME configuration!
Here is output of debug ccsip messages:
Jun 11 11:23:20.217: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:3002@172.16.51.19 SIP/2.0
From: sip:3600@172.16.51.33:5060;tag=05dcb7ce87774d069741ccee62a4dacb
To: sip:3002@172.16.51.19
Via: SIP/2.0/TCP 172.16.51.33:5060;branch=z9hG4bKf5cf33b7069d4e9b8edf0265a531f008
Max-Forwards: 70
Contact: sip:3600@172.16.51.33:5060
Call-ID: 3f26d8a300ab4a91af5ad7fa745f8c2f@172.16.51.19
CSeq: 300 NOTIFY
Content-Length: 23
.Jun 11 11:23:20.217: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 11 Jun 2009 11:23:20 GMT
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
CSeq: 300 NOTIFY
I configured according the following document - Cisco Unified Communications Manager Express SIP Trunk Integration Guide for Cisco Unity Connection Release 7.x
Did you resolve the your problem?
Can you suggest me what to do?
Milan
its 6am and i still have figured it out yet.
i did come across these documents though.
http://supportwiki.cisco.com/ViewWiki/index.php/When_using_the_MWI_Subscription_and_Notify_feature,_Cisco_CallManager_Express_sends_the_481_Call_Leg/Transaction_Does_Not_Exist_error_message_in_response_to_the_NOTIFY
AND http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K19941794
I downgraded to an IOS that is listed as fixed and i am still getting the error. although this probably applies moreso to you things you are using CUE, I am not.
can you download Wireshark.org and check out the conversation in the protocol filter? we could compare our dumps to see if they are similar and doing the same thing. i hope to have this fixed soon and gain my life back..ha
i'm not that familiar with CUC but if your voicemail is elsewhere i think you might have to enable mwi relay under telephoney service and configure an MWI server under the SIP-UA.
I'm running Exchange 2010 UM, UC540 w/ CME 8/IOS 15.
I followed the guide from this site:
http://www.aaronhall.net/cisco-cme-exchange-unified-messaging.html#more-216
And our MWI is working like a charm, thought this might help.
-Shaun
Same. looking for the guide but the web site seems to be down.
Would appreciate any help ....
Best
D.
4406
