Community Member
My Call Manager Backup just doubled in size. We changed nothing
Backing up the publisher server we normally have a 680 mb backup. There haven't been any particular dramatic changes. A user update here and a user update there. All of a sudden my backup is 1.26 gb. Any ideas?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: My Call Manager Backup just doubled in size. We changed noth
Hi Ross,
The size of the backup will vary due mainly to the volume of CDR records. You probably have the system set to purge the records at a specific time. This is why the backup size could be quite high one week (before purge) and quite low the following week (after purge). Here is a great explanation of the backup file size from Gonzalo@Cisco;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddbcc53/0#selected_message
Hope this helps!
Rob
Hi Ross,
Hope this helps!
Rob
Community Member
Very good. Makes sense. Thank you for your help. Much appreciated.
Community Member
Are you backing up CDR?
I've experienced it before where CDR had been turned on in the callmanager but was not functioning. A subsequent reboot caused CDR to function.
If this is your case and you are in fact backing up CDR, depending on call volume, your backup size could skyrocket.
later,
Go0se
277
