My SIP Ip Phone doesn´t working music on hold
Hi friends, I have SIP IP PHONES that do not send music on hold to SCCP Phones, I have revised the configuration and I don't find the solution. Someone has any answer to solve this issue. My CUCM is 9.1 BE6K.
Thank you
1 REPLY
Re: My SIP Ip Phone doesn´t working music on hold
Have you checked the basics for MOH problems????
MRG?? MRGL?? Device pool?? Codec?? MOH on all servers???
java
if this helps, please rate
www.cisco.com/go/pdi
169
