05-10-2010 08:56 AM - edited 03-15-2019 10:41 PM
Hi all
My problem is to provide on phone display, Name of caller instead of number if present in directories.
My possible scenario would be:
- Cisco Cucm 7.1 single site (publisher + subscriber)
- N.2 h323 voice gateway Cisco 2800 with 2 E1 controller each (one per company) to redundate the gateway.
- 1 NM-CUE on the first router for voice mail and auto-attendant
Personal and group Directories should be implemented using embedded UCM directory system (using end user personal directories) and associate services to the devices.
My need is to have name lookup of corporate and personal directories on the phones.
If not possible look up in native Cucm directories, could you suggest me the way this is possible and how to do it?
Thank you very much
Emanuele
Solved! Go to Solution.
05-10-2010 06:36 PM
CUCM does not do name to number lookup as you describe. There are several threads on the forums on this topic. Really, the only way to do this is to write a custom script of your own or find a 3rd-party that already has implemented one.
Hailey
Please rate helpful posts!
05-10-2010 12:48 PM
Hey Emanuele,
I don't know of a way to do this in callmanager. Calls from the outside are going to use the cname that comes in through the trunk. The only way I know of to do this is route your incoming calls through an asterisk box first and tag the names. You can even install a service that will do a reverse lookup on the number if the name isn't in your directory. http://bestof.nerdvittles.com/applications/callerid/
hth
Rick
05-10-2010 06:36 PM
Hailey
