National Call gets Disconnect Cause=34
Hello partners,
I will explain the situation:
- The called number is 002812677847 and the dial-peer 4 strip the fisrt 0
- Only with national call the router receive Disconnect Cause=34, with other calls the function is OK, in the following extract of the debug voice ccapi inout you will see the Disconnect Cause=34:
004762: May 14 17:14:58.933 CCS: //-1/80EE2CFD960B/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=Spider Conferencias OP/TEC P5
   ----- ccCallInfo IE subfields -----
   cisco-ani=2127717500
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=002812677847
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
004763: May 14 17:14:58.933 CCS: //-1/80EE2CFD960B/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x296B83DC, Call Info(
   Calling Number=2127717500,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=002812677847(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=100, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=8607
004764: May 14 17:14:58.933 CCS: //-1/80EE2CFD960B/CCAPI/ccCheckClipClir:
   In: Calling Number=2127717500(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
004765: May 14 17:14:58.933 CCS: //-1/80EE2CFD960B/CCAPI/ccCheckClipClir:
   Out: Calling Number=2127717500(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
004766: May 14 17:14:58.937 CCS: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004767: May 14 17:14:58.937 CCS: :cc_get_feature_vsa malloc success
004768: May 14 17:14:58.937 CCS: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004769: May 14 17:14:58.937 CCS:  cc_get_feature_vsa count is 1
004770: May 14 17:14:58.937 CCS: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004771: May 14 17:14:58.937 CCS: :FEATURE_VSA attributes are: feature_name:0,feature_time:709733944,feature_id:8607
004772: May 14 17:14:58.937 CCS: //8607/80EE2CFD960B/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=2127717500(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=002812677847(TON=Unknown, NPI=Unknown))
004773: May 14 17:14:58.937 CCS: //8607/80EE2CFD960B/CCAPI/cc_process_call_setup_ind:
   Event=0x31695A00
004774: May 14 17:14:58.937 CCS: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 002812677847
004775: May 14 17:14:58.937 CCS: //8607/80EE2CFD960B/CCAPI/ccCallSetContext:
   Context=0x2A4DDA9C
004776: May 14 17:14:58.937 CCS: //8607/80EE2CFD960B/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 8607 with tag 100 to app "_ManagedAppProcess_Default"
004777: May 14 17:14:58.937 CCS: //8607/80EE2CFD960B/CCAPI/ccCallProceeding:
004778: May 14 17:14:58.937 CCS: //8607/80EE2CFD960B/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=4, Params=0x2A4DC7E4, Progress Indication=NULL(0)
004779: May 14 17:14:58.937 CCS: //8607/80EE2CFD960B/CCAPI/ccCheckClipClir:
004780: May 14 17:14:58.937 CCS: //8607/80EE2CFD960B/CCAPI/ccCheckClipClir:
004781: May 14 17:14:58.937 CCS: //8607/80EE2CFD960B/CCAPI/ccCallSetupRequest:
   Destination Pattern=002........., Called Number=002812677847, Digit Strip=TRUE
004782: May 14 17:14:58.937 CCS: //8607/80EE2CFD960B/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=
   Account Number=Spider Conferencias OP/TEC P5, Final Destination Flag=TRUE,
   Guid=80EE2CFD-DAE3-3137-960B-84010AE39C03, Outgoing Dial-peer=4
004783: May 14 17:14:58.937 CCS: //8607/80EE2CFD960B/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=002812677847
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
004784: May 14 17:14:58.937 CCS: //8607/80EE2CFD960B/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x29CE4410, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=2127717500,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=002812677847(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=4, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
004785: May 14 17:14:58.937 CCS: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004786: May 14 17:14:58.937 CCS: :cc_get_feature_vsa malloc success
004787: May 14 17:14:58.937 CCS: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004788: May 14 17:14:58.937 CCS:  cc_get_feature_vsa count is 2
004789: May 14 17:14:58.937 CCS: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004790: May 14 17:14:58.937 CCS: :FEATURE_VSA attributes are: feature_name:0,feature_time:709733720,feature_id:8608
004791: May 14 17:14:58.937 CCS: //8608/80EE2CFD960B/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
004792: May 14 17:14:58.937 CCS: //8608/80EE2CFD960B/CCAPI/ccCallSetContext:
   Context=0x2A4DC794
004793: May 14 17:14:58.937 CCS: //8607/80EE2CFD960B/CCAPI/ccSaveDialpeerTag:
VZAMRVOIP2#Outgoing Dial-peer=4
VZAMRVOIP2#
004794: May 14 17:15:02.033 CCS: //8608/80EE2CFD960B/CCAPI/cc_api_call_proceeding:
   Interface=0x29CE4410, Progress Indication=NULL(0)
004795: May 14 17:15:03.689 CCS: //8608/80EE2CFD960B/CCAPI/cc_api_call_disconnected:
   Cause Value=34, Interface=0x29CE4410, Call Id=8608
004796: May 14 17:15:03.689 CCS: //8608/80EE2CFD960B/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=34, Retry Count=0)
004797: May 14 17:15:03.689 CCS: //8607/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
004798: May 14 17:15:03.689 CCS: //8608/80EE2CFD960B/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=8608
004799: May 14 17:15:03.689 CCS: //8608/80EE2CFD960B/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=34)
004800: May 14 17:15:03.689 CCS: //8608/80EE2CFD960B/CCAPI/ccCallDisconnect:
   Cause Value=34, Call Entry(Responsed=TRUE, Cause Value=34)
004801: May 14 17:15:03.741 CCS: //8608/80EE2CFD960B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x29CE4410, Tag=0x0, Call Id=8608,
   Call Entry(Disconnect Cause=34, Voice Class Cause Code=0, Retry Count=0)
004802: May 14 17:15:03.741 CCS: //8608/80EE2CFD960B/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
004803: May 14 17:15:03.741 CCS: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004804: May 14 17:15:03.741 CCS: :cc_free_feature_vsa freeing 2A4DAD50
004805: May 14 17:15:03.741 CCS: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004806: May 14 17:15:03.741 CCS:  vsacount in free is 1
004807: May 14 17:15:03.741 CCS: //8607/80EE2CFD960B/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
004808: May 14 17:15:03.741 CCS: //8607/80EE2CFD960B/CCAPI/ccCallDisconnect:
004809: May 14 17:15:03.741 CCS: //8607/80EE2CFD960B/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
VZAMRVOIP2#
004810: May 14 17:15:03.741 CCS: //8607/80EE2CFD960B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x296B83DC, Tag=0x0, Call Id=8607,
004811: May 14 17:15:03.741 CCS: //8607/80EE2CFD960B/CCAPI/cc_api_call_disconnect_done:
004812: May 14 17:15:03.741 CCS: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004813: May 14 17:15:03.741 CCS: :cc_free_feature_vsa freeing 2A4DAE30
004814: May 14 17:15:03.741 CCS: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004815: May 14 17:15:03.741 CCS:  vsacount in free is 0
Here is the router config:
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service tcp-small-servers
service sequence-numbers
service counters max age 5
hostname VZAMRVOIP1
boot-start-marker
boot system flash c2900-universalk9-mz.SPA.152-1.GC1.bin
boot-end-marker
card type e1 0 0
security authentication failure rate 10 log
security passwords min-length 6
logging buffered informational
logging console informational
enable secret 5 $1$Uq.Q$H.NWgH0a1DDlZG4pmcrkC.
aaa new-model
aaa authentication login AUTH-VTY group tacacs+ local
aaa authentication login AUTH-CON local-case
aaa authorization exec AUTH-VTY if-authenticated
aaa authorization commands 1 AUTH-VTY if-authenticated
aaa authorization commands 15 AUTH-VTY local group tacacs+
aaa accounting update newinfo
aaa accounting exec AUTH-VTY start-stop group tacacs+
aaa accounting commands 1 AUTH-VTY stop-only group tacacs+
aaa accounting commands 15 AUTH-VTY stop-only group tacacs+
aaa accounting connection AUTH-VTY stop-only group tacacs+
aaa session-id common
clock timezone CCS -4 30
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
no ipv6 cef
no ip source-route
no ip gratuitous-arps
no ip bootp server
no ip domain lookup
ip domain name bes.gbes
ip cef
login on-failure log
login on-success log
isdn switch-type primary-net5
voice-card 0
voice call disc-pi-off
no voice call carrier capacity active
voice service voip
 h323
  no h225 timeout keepalive
  call preserve limit-media-detection
voice class codec 100
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729r8
voice translation-rule 1
 rule 1 /^75/ /11/
 rule 2 /^76/ /12/
 rule 3 /7700/ /004146210261/
voice translation-profile INCOMING
 translate called 1
license udi pid CISCO2911/K9 sn FTX1522AM0J
license accept end user agreement
hw-module pvdm 0/0
archive
 log config
  logging enable
  logging size 1000
  notify syslog contenttype plaintext
  hidekeys
 path flash0:/LOGS_CONFIG
 write-memory
redundancy
controller E1 0/0/0
 framing NO-CRC4
 line-termination 75-ohm
 pri-group timeslots 1-31
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 192.168.159.141 255.255.255.240
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed 1000
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn timer T310 120000
 isdn incoming-voice modem 64
 no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.158.159.129
ip tacacs source-interface GigabitEthernet0/0
logging origin-id hostname
logging facility local0
logging source-interface GigabitEthernet0/0
logging 10.227.154.13
control-plane
voice-port 0/0/0:15
 translation-profile incoming INCOMING
 disc_pi_off
 echo-cancel coverage 32
 cptone VE
 bearer-cap Speech
mgcp profile default
dial-peer voice 1 pots
 incoming called-number .
 direct-inward-dial
 forward-digits all
dial-peer voice 2 pots
 description ** Llamadas locales desde la CPA **
 destination-pattern 0[1-9]......
 port 0/0/0:15
 forward-digits 7
dial-peer voice 3 pots
 description ** Llamadas 0800 y 0500 desde la CPA **
 destination-pattern 90[5,8]0........
 port 0/0/0:15
 forward-digits 11
dial-peer voice 4 pots
 description ** Llamadas Nacionales desde la CPA **
 destination-pattern 002.........
 port 0/0/0:15
 forward-digits 11
dial-peer voice 5 pots
 tone ringback alert-no-PI
 description ** Llamadas Celulares Movistar desde la CPA**
 destination-pattern 004[1,2]4.......
 port 0/0/0:15
 forward-digits 11
dial-peer voice 6 pots
 description ** Llamadas Celulares Movilnet y Digitel desde la CPA**
 destination-pattern 004[1,2][2,6].......
 port 0/0/0:15
 forward-digits 11
dial-peer voice 7 pots
 corlist outgoing Internacional
 description ** Llamadas Internacionales desde la CPA **
 destination-pattern 00T
 port 0/0/0:15
 forward-digits all
dial-peer voice 9 pots
 description ** Llamada al 171  **
 destination-pattern 0171
 port 0/0/0:15
 forward-digits 3
dial-peer voice 10 pots
 corlist outgoing Especial
 destination-pattern 171
 port 0/0/0:15
 forward-digits all
dial-peer voice 100 voip
 destination-pattern 1...
 session target ipv4:10.227.159.135
 incoming called-number .T
 voice-class codec 100
 dtmf-relay h245-alphanumeric
dial-peer voice 101 voip
 preference 2
 session target ipv4:10.227.152.135
dial-peer voice 9000 voip
 destination-pattern 9...
 no vad
dial-peer voice 9001 voip
 preference 2
 no vad
dial-peer voice 10000 pots
 destination-pattern 04146598490
 port 0/0/0:15
 forward-digits all
dial-peer voice 11 pots
 corlist outgoing Local
 description ** Llamadas Emergencias 113 Caracas **
 destination-pattern 0113
 port 0/0/0:15
 forward-digits 3
dial-peer voice 12 pots
 destination-pattern 113
 port 0/0/0:15
 forward-digits all
gateway
 timer receive-rtp 1200
gatekeeper
 shutdown
I know that Disconnected Cause No. 34 - no circuit/channel available [Q.850]:
This cause indicates that there is no appropriate circuit/channel presently available to
handle the call.
So, the question is: the disconnected cause=34 in this case mean that is a 100% service-provider issue.
Thanks in advance
Ronald García
1 ACCEPTED SOLUTION
Hello Ronald, Yes, the
Hello Ronald,
Yes, the provider call leg is first disconnected and it seems issue with provider. you may also collect 'debug isdn q931' for another test national call and a working call and check the channel numbers. Mostly the issue should be with provider side. Please have a word with  them
//Suresh
Please rate all the helful posts
//Suresh Please rate all the useful posts.
1 REPLY
Hello Ronald,
//Suresh
407
