National Number prefix not displayed on phones when transferring a call
Hello everybody!
We have a customer whose CCM-Cluster is connected to a traditional PBX
via a QSIG E1. The CCM-Cluster has no PSTN-lines, the PSTN-lines are all
in the PBX.
PSTN -----ISDN/E1----- PBX -----QSIG/E1----- CCM.
We are adding a 0 as access code and a 0 for national number type for
incoming PSTN calls to the calling number according to this document:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805b6f33.shtml#ccm2
So we have filled in the 4 number prefix fields and when an external
number is calling a ccm-phone we get the correct number displayed (with
the leading 0s) and the number is also dialable from missed numbers list.
For example : 4234562222 is displayed on phone with 004234562222
But when an external caller is dialing an extension in the PBX and this
extension is transferring the call to a ccm-extension the leading digits
are not prefixed. The number on the display of an ip-phone is 4234562222.
In CCM-trace i can see that the calling party number is sent to
callmanager in a facility-message with correct numbering plan type
(national).
CCM-trace shows also that CCM is recognizing it as an national number:
02/18/2009 12:48:42.452 CCM|TRANSFQSIGASN - StructuredOutput:value
CTCompleteRose ::= invoke :
invokeID 2560,
operationValue localValue : 12,
argument
endDesignation secondaryEnd,
redirectionNumber presentationAllowedAddress :
partyNumber publicPartyNumber :
publicTypeOfNumber nationalNumber,
publicNumberDigits "4234562222"
screeningIndicator userProvidedNotScreened
callStatus answered
But the National Number Prefix is not added on the phone display.
Customer has 4.1.3 SR2
I see the same behavoir in my lab with 6.1.3 and another PBX-vendor, so
i do not think it is a bug, i believe it is either an config issue or it
is just not supported.
Any ideas?
1 ACCEPTED SOLUTION
Re: National Number prefix not displayed on phones when transfer
Yes, we have a feature request running for that but we did not get an information when it will be integrated.
we have the same problems with our PBX System and UCM 6.1/6.2. The problem ist that the PBX is sending the national/international information in a different IE Field and the UCM ist not able to interpret this information field. Maybe we have a new chance with the 7.0.x Version of UCM because there are some new features with calling number normalization.
OK, that is what i have supposed. Have you confirmed this information by TAC?
Thank you very much for that information.
154
