need a corlist guru
Customer has a UC520 trying to separate only 911 calls between two sites. Remote site has a gateway with fxo port. This is the set up I used and when the customer at hartford end calls 911 it goes out the wtby end instead of out the pri. Happens every single time. If you remove the voip peer the call goes out
the pri. I don't get it.
dial-peer cor list call-911-htfd
member emergency
dial-peer cor list call-911-wtby
member emergency
dial-peer voice 155 pots
corlist outgoing call-911-htfd
description ** T1 pots dial-peer **-Emergency dial-peer
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
destination-pattern 911
port 0/3/0:23
forward-digits 3
no sip-register
dial-peer voice 4000 voip
corlist outgoing call-911-wtby
description ** Waterbury Emergency Dial Peer **
session target ipv4:10.1.2.2
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
ephone-dn 19 dual-line
number 5824 secondary 5824 no-reg primary
label Esther Burgos 5824
description Esther Burgos
name Esther Burgos
call-forward busy 5809
call-forward noan 5809 timeout 10
corlist incoming call-911-
1 REPLY
Re: need a corlist guru
I believe you would need something like (parts omitted):
dial-peer cor custom
name 911-htfd
name 911-wtby
member 911-htfd
member 911-wtby
corlist incoming call-911-htfd
ephone-dn 20 dual-line
corlist incoming call-911-wtby
In this case, ephone-dn 19 would use dial peer 155 and ephone-dn 20 would use dial peer 4000.
Hope this helps.
Brandon
123
