Need a report or list on all stations with CFwdAll active
CCM 4.2
How can I get a list of all telephone stations that have the CFwdAll (call forwarding) on and it's destination? Thanks
1 ACCEPTED SOLUTION
Re: Need a report or list on all stations with CFwdAll active
Drill down to Microsoft SQL Servers -> SQL Server Group -> -> Databases -> (This should be similar to CCM0301 and should have a hand under it indicated that it is published) -> Tables. In the right-hand pane, you should see a table named NumPlan. Right-click this table and choose Open Table -> Return all rows.
Hope this helps.
Brandon
You can use SQL to get this information. Open SQL Enterprise Manager and drill down to the tables of you current CCM database. Open the NumPlan table. The CFADestination column will tell you those DNs that have CFwdALL on and what the destination is. You can also look at the CFAVoiceMailEnabled column to see those DNs that have CFwdALL to voicemail turned on.
Hope this helps. If so, please rate the post.
Brandon
I'm in the SQL Enterprise Manager but not sure where to go. Can you be more specific?
Hope this helps.
Brandon
Thanks a Million...this helps BIG time!
I'm not a huge fan of using SQL enterprise manager to browse the tables, as it is easy to make a mistake and overwrite data. I much prefer SQL Query analyzer.
This query in the CCM0300 database will give you the same information, in a much safer fashion.
select dnorpattern,
callingsearchspace.name,
cfadestination
from numplan,callingsearchspace
where callingsearchspace.pkid = fkcallingsearchspace_cfa
Hope that helps!!
This doesn't capture CFA to voicemail though does it? I use the following:
select n.dNorPattern as 'pattern',rp.name as 'routePartitionName',n.cFAVoiceMailEnabled as 'cfa-vm',n.cFADestination as 'cfa-dest'
from NumPlan as n
inner join RoutePartition as rp on rp.pkid = n.fkRoutePartition
where ((n.cFAVoiceMailEnabled=1)or(n.cFADestination != ''))
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
183
