need a sample cme with multiple fxo ports, hunt fashion
hi,
anyone kind enough to provide a sample working configuration of multiple fxo ports (each being a pstn line) and I assuming the telco is doing hunting...
so let's say 4 lines, if line 1 is busy the call is sent by the telco on line 2 and so on...
incoming and outgoing.
thank you very much!!
I did google it and can't find anything with multiple fxo ports.
Hall of Fame Super Silver
Incoming you have not control as that is telco driven, all you need is "connection plan XXXX" where XXXX is the destination of the call on the voice-port.
For outbound create a trunk group, assign the trunk group to each port with appropriate priority and then build a dial peer that points to the trunk group.
HTH,
Chris
trunk group 1
max-calls voice 4 (or however many POTS lines you want to use)
hunt-scheme round-robin (or whatever method you like)
voice-port 0/0/0
trunk-group 1
connection plar opx XXXX (extension)
caller-id enable
voice-port 0/0/1
trunk-group 1
caller-id enable
voice-port 0/0/2
trunk-group 1
caller-id enable
voice-port 0/0/3
trunk-group 1
caller-id enable
dial-peer voice 1 pots ( I like creating this for troubleshooting, by default cisco router accept incoming calls)
trunkgroup 1
incoming called-number .
direct-inward-dial
dial-peer voice 2 pots
trunkgroup 1
destination-pattern 8[2-9]......           (8 for an outside line or 9 or nothing, then adjust your forward-digits to match)
forward-digits 7
dial-peer voice 3 pots
trunkgroup 1
destination-pattern 81[2-9]..[2-9]......
forward-digits 11
dial-peer voice 4 pots
trunkgroup 1
destination-pattern 8911
forward-digits 3
dial-peer voice 5 pots
trunkgroup 1
destination-pattern 911
forward-digits 3
734
