Need assistance with Discard Digit Instructions
Hi all,
I am building route patterns for International calls. I have tried to find the definition of a DDI, but have been unsuccessful in my search.
The DDI is: PreDot IntlAccess IntlDirectDial
What does this particular DDI do?
Also, What does the IntlTollBypass do (pertaining to discarding of digits.
Finally, the difference between predot and PreAt. I understand what they do (PreDot removes all characters to the left of the decimal and PreAt removes all characters to the left of @, but what is the difference from a design perspective? When do you use one, versus the other?
-Thanks in advance
Re: Need assistance with Discard Digit Instructions
i don't have a CUCM at hand right now and the examples are not available on web but if you go to the route pattern page and click on help -> For this page, when it shows the discard section there should be a link that has an example for every option that shows what was the original input, discard option and output.
java
if this helps, please rate
java
www.cisco.com/go/pdi
The odd thing about this is that I have done that and the DDI for PreDot IntlAccess IntlDirectDial are not listed in my help file.
You can find the discard digits definitions on this link:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmsys/a03rp.html#wp1043708
But as you saw, it is missing the definition for PreDot IntlAccess IntlDirectDial (looks like a bug in the documentation)
When a international call hits a 9.@ Route Pattern with PreDot IntlAccess IntlDirectDial, the 011 is discarded automatically. The Called Number Plan will be marked as ISDN and with Type International.
For example if we dial 9011442055551122#, the called number gets
translated to 442055551122 Plan ISDN Type International.
Regarding the preDot vs preAt:
When the route pattern contains the @ wildcard, callmanager routes calls according to the numbering plan configured, so the wildcard @ will match every dialed patter and you need to use DDI to do more specific patterns
If you don't use @ you need to create each match, like 9.[2-9]...... for 7 digits calls local calls
9.1[2-9]..[2-9]...... for LD
9.011! for Intl calls.
On these route patterns you need to use preDot instead of preAt to discard the 9
regards
642
