Need assistance with FXO ports
I have a 2801 router with a 4 port FXO card in it. I have four POT lines coming into the router. I need some help with sending calls to the ports, can someone post configs on how to have the router send calls from my CCM to the POT lines?
Adam
Re: Need assistance with FXO ports
Adam,
The following documents will show you how to configure your gateway to work with CCM using MGCP. One caveat to keep in mind is that you cannot use caller ID with MGCP FXO ports. If you need caller ID, you'll need to configure the gateway to use H.323.
Configuring the Cisco IOS MGCP Gateway
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008017787b.shtml
Configure MGCP Gateway and FXO/FXS Ports on a Cisco CallManager Server
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008017825e.shtml
Hope this helps. If so, please rate the post.
Brandon
If possible I would prefer to use H323. But If that route doesn't work I will try the MGCP route.
Take a look at the following link for configuring an H.323 gateway for use with CCM.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094636.shtml
Brandon
286
