Community Member
Need clarification on db replication
Hi there,  a quick question: from the following screenshot based on cucm unified CM DB Status, can any one confirm to me that there is database replication issue here.
Screenshot A indectate that both database are 2 which is good. but screenshot B shows there are is problem. which one is correctly reflecting the database replication status?
Screenshot A
All servers have a replication   count of 541.
All servers have a good   replication status.
Server
Number   of Replicates Created
Replicate_State
10.103.35.6
541
2 - good
10.103.35.7
541
2 - good
Screenshot B
Replication Server List (cdr list   serv) from every server for debugging purposes only.
Server
cdr   list serv
10.103.35.6
SERVER                   ID STATE   STATUS     QUEUE   CONNECTION CHANGED
g_ausyd1as_41_ccm8_6_2_21900_5  2 Active     Local           0
g_ausyd1as_42_ccm8_6_2_21900_5   3 Active     Connected       0 May 17   20:28:31
10.103.35.7
g_ausyd1as_41_ccm8_6_2_21900_5   2 Active     Connected       0 May 17   20:28:31
g_ausyd1as_42_ccm8_6_2_21900_5  3 Active     Local           0
1 ACCEPTED SOLUTION
Purple
Hi Roy,
Both the screenshots are correct.
First screenshot shows DBreplication which is fine.
Second Screenshot also shows replication and is OK.HAd DBReplication been problem , it would have shown DROPPED instead of Active.Values 2 and 3 correspond to ID State[which could be identity] of Pub abd SUB. Had there been third server in cluster, it would have ID state as 4.
regds,
aman
Purple
Hi Roy,
Can u share the output of utils dbreplication runtimestate from Publisher using CLI?
regds,
aman
Purple
Hi Roy,
regds,
aman
Community Member
Hi aman,  thanks for the reply.  the result from "untils dbreplcation status" is same as the scrrenshot B, I was bit confuresed with 2 and 3 in the screenshot B. thanks for clarifying this.... cheers Roy
Purple
Hi Roy,
Thanks for rating.
regds,
aman
Community Member
Hello Roy / Aman,
The below Information may help i believe.
Replicate_State counter
Use the Syslog viewer in the Cisco Unified Communications Manager Real-Time Monitoring Tool (RTMT) in order to check the Replicate_State counter for the Number of Replicates Created and State of Replication object on all nodes. The value on each node must equal 2. This counter represents the state of replication, which includes these possible values:
  • 0 (Not Started)—No subscribers exist or the Database Layer Monitor service is not running and has not been running since the subscriber was installed.
  • 1 (Started)—Replication is currently being setup.
  • 2 (Finished)—Replication setup is completed and working.
  • 3 (Broken)—Replication failed during setup and is not working.
  • 4—Replication is not setup correctly.
Note: This information is the same for Cisco CallManager version 5.1(3) and all 6.1 versions.
M.Madhusudhana Rao
228
