Need Configuration example Dial Peer/SIP trunking between CUCM & UCME.
I have 2821 CME at remote location and Cisco UCM at Main location.   I need dial peer/SIP trunking over MPLS WAN connection configuration example for this..
DO any have it?  Please suggest any related soultion or exmaple link.
Sandip
Aaron Harrison
Just use H.323.
1) Add a H.323 gateway to CCM, with the CME IP
2) Point a route pattern at the H.323 gateawy
3) Add a dial-peer on the CME pointing at the CCM IP
4) Add resilient duplicate dial-peers with lower preference pointed at your lower-order call processing CCMs
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Sandip,
Follow the steps that Aaron said. If you want to check those steps in detail with examples, you can use this documents as a guide:
H.323 Gateway Configuration Between CallManager Express and CallManager
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_configuration_example09186a00808ebbfe.shtml
H.323 Gateway Dial-Peer Configuration for Cisco CallManager Server Redundancy
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_configuration_example09186a0080094852.shtml
Hope to help, if it does please rate.
- Adrián.
