Need Example CME with PRI Translation Examples
I am looking for some example CME (or UC500) router configs that have a PRI and are using "translation-profiles".
I don't have a 1-to-1 DID to extension dial-plan so basically am looking for translation profiles that strip outgoing digit (like 9 to dial out) and map certain DIDs to incoming extensions.
Figured if I have a few configs that work, I could figure the best solution for me.
Anyone have a few configs they could post using PRIs with Translation-profiles?
(NOTE: My config will grow a bit more complex because I have two sites each which will have a PRI and "back each other up" via a private IP WAN. So a pri failure at site a will cause the calls to route out site b's pri. So if you have something like this EVEN BETTER!)
I will rate anyone who posts a config. Thanks!
Re: Need Example CME with PRI Translation Examples
A couple of things to consider:
1. You don't need to strip your access code with a translation rule. This is done with a dial peer such as:
dial-peer voice 1 pots
destination-pattern 9[2-9]......
forward-digits 7
This dial peer will send only 7 digits beginning from the right most digit.
2. One option to DIDs that do not match your numbering plan is to use secondary numbers. This is especially useful if you have a large number since you are limited to 15 rules in a voice translation rule.
ephone-dn 10 dual-line
number 1000 secondary 1235551212
Hope this helps.
Brandon
Thanks, this makes sense... but it leads to a couple of questions:
1) The "forward-digits" will be useful. I don't want to use the .T and will be setting up a "7 digit dialpeer", "10 digit dialpeer", "international", etc.
Part of the problem is that they have to use 10 digit dialing on their PRI (their area requires it) but I want to allow them to dial 7 digit for local calls. Hence some translation is required. I also want to add the "8" on inbound calls so they can call people back right from the phone's "call log". I think translation is the only way I can do that. Yes?
2) The secondary number is interesting, like you said, especially for DID routing. Does the "secondary" number have any impact on anything that might use that second line (call waiting, conferencing, message waiting indicator is on 1000, etc)?
Thanks for the reply!
1. You can handle the 10/7 digit issue with dial peers although depending on the number of local prefixes it might take quite a few.
destination-pattern 9456....
forward-digits 7
prefix 123
This will give you a called number of 123456....
You can also combine multiple contiguous prefixes like this:
dial-peer voice 2 pots
destination-pattern 945[678]....
forward-digits 7
prefix 123
This dial peer would match any 7 digit number beginning with 456, 457 or 458
Yes, translation is the only way to prepend the 8 on incoming calls.
2. The only area I can think of where the secondary number has an effect is voicemail. If someone calls the secondary number and it gets forwarded to voicemail, CUE will need to know about this secondary number to route the call properly. You can enter the secondary number in CUE in the field for an E.164 number.
Hope this helps.
Brandon
366
