Need extra DSP resources
I need to order a PVDM II 32 for my 2821.
My question is can my current hardware support the dsp if so where would I put the new pvdm II in my current hardware?
dfwdls-2821-01#sh inventory
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821 , VID: V04, SN:
NAME: "One port T1 voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "On
e port T1 voice interface daughtercard"
PID: VWIC-1MFT-T1= , VID: 1.0, SN:
NAME: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot
2", DESCR: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-1MFT-T1/E1 , VID: V01 , SN:
NAME: "PVDMII DSP SIMM with Two DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SI
MM with Two DSPs"
PID: PVDM2-32 , VID: NA , SN:
Re: Need extra DSP resources
What do I need to purchase if I need to add a 3rd PVDM II 32 DSP?
The ISR 2821 does have three PVDM slots, therefore it is possible to add a 3rd PVDM2-32 if required.
However carefully plan your DSP resources, especially if you are looking at transcoding and conferencing in mixed moded (G711 and G729) including your voice-channel for any FXO, FXS are Digital PRI.
Allan.
Thank you to both of you. I have one last question.
How many dsp slots am I currently occupying in this 2821? How can you tell from my original command? Or is there another command I need to run to find this information out?
124
