Need help for Australia E1 x 2
I am configuring a E1 PRI in Australia connected to a 3935 GW which has a SIP trunk to a 8.6 Call Manager. The circuit is in and good with no errors and inbound calls from the PSTN work fine. However, outbound calls connect but there is no audio from the Call Manager to the PSTN however the call manager phones can hear the PSTN side, i.e.:
  • If a call originates from the PSTN both sides hear good audio
  • If the call originates from a Call-manager registered phone the PSTN side does not get audio but the Call Manager side does.
Cisco verified that the audio is making is way from the phone to the gateway correctly and says the issue is a carrier issue which of course Telstra disagrees with. I have pasted the santized gateway config below. Does anybody have any ideas?
service password-encryption
service sequence-numbers
hostname voiprouter
boot-start-marker
boot system flash0:c3900-universalk9-mz.SPA.152-1.T1.bin
boot system flash0:c3900-universalk9-mz.SPA.151-4.M2.bin
boot-end-marker
card type e1 0 0
logging buffered 1000000
enable secret 5 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
aaa new-model
aaa authorization exec default local
aaa session-id common
clock timezone CET 11 0
network-clock-participate wic 0
no ipv6 cef
ip traffic-export profile test mode capture
  bidirectional
no ip domain lookup
ip domain name au.ncite
ip cef
isdn switch-type primary-net5
isdn voice-call-failure 0
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
  ipv4 <Call Manager IP>
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice hpi capture buffer 1000000
voice hpi capture destination flash:pcm.dat
application
global
  service alternate default
license udi pid C3900-SPE100/K9 sn FOC15330TE6
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
pri-group timeslots 1-31
ip ssh version 2
ip scp server enable
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address XXXXXXXXXXXX 255.255.255.192
ip traffic-export apply test size 2000000
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex full
speed 1000
media-type rj45
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no logging event link-status
no snmp trap link-status
isdn incoming-voice voice
no cdp enable
router rip
network XXXXXXXXX
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 XXXXXXXXXXX
nls resp-timeout 1
cpd cr-id 1
control-plane
voice-port 0/0/0:15
cptone AU
bearer-cap Speech
voice-port 0/1/0
voice-port 0/1/1
mgcp profile default
dial-peer voice 100 voip
preference 1
destination-pattern 62690...
session protocol sipv2
session target ipv4:<Call Manager IP>
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 200 pots
destination-pattern 0
direct-inward-dial
port 0/0/0:15
dial-peer voice 300 voip
incoming called-number .T
dtmf-relay rtp-nte
codec g711ulaw
no vad
gatekeeper
shutdown
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address XXXXXXXX port 2000
max-ephones 50
max-dn 100
Green
Nathan,
Can you post
show ip int brief
This is usualy an IP routing issue
Alex
Regards, Alex. Please rate useful posts.
Hi Nathan
Can you also post a show voice call status for both incoming and outgoing call?
Carlo
Please rate all helpful posts "The more you help the more you learn"
This was a bug in IOS. Going from 15.2T to 15.1M resolved the issue. As I said, we (Cisco and me)  verified IP routing, we verified that the actual voice media packet was getting to the gateway but there was just no voice. Finally I  went from a 15.2T train to a 15.1M load and it worked like a champ.
328
