Need help in connecting two CMs throught pt 2pt for 4 digit dialing
We were purchased by another company we are running 4.1 they are running 5.1 we are on 4digit ext 2200's and they are on 1700's. What do I configure to get these 2 CMs to talk to each other gateway??? Any help would be greatly appreciated.
1 REPLY
Re: Need help in connecting two CMs throught pt 2pt for 4 digit
u can do it in several ways
u can make what is called inter cluster trunk ICT which connect the two CMs directly and when u make for example a route-pattren to that company
like 1XXX
and on the gatway or route list chose the ICT u creat it which contain thier CM IP
and also they have to do the same thing on thier side in opest direction
they have to make route=pattern with 2XXX
or
u might have a gateway H323
and IP connectivity either with thier gateway or CM
make voip dial-peer point to either thier gateway if they use a gateway or directly to thier CM in this case they have to add ur H323 gateway to thier CM
for example lets say thier gateway Ip 1.1.1.1 and they need from u to dial the extentions directly without adding any more digits
on the h323 do
dial-peer voice 1 voip
destination-pattren 1...
session target ipv4:1.1.1.1
with h323 when u do this also do the following command
voice service-voip
allow connection h323-to-h323
the following link for ICT config (useful)
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094729.shtml
good luck
please Rate if helpful
92
