Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Need help locating CME 8 tar install file on CCO
I'm trying to locate the CME 8 tar file so that I can install CME on my IOS 15.1 router (2821).  I'm only able to find the files for CME 7 and IOS 12.4 at http://www.cisco.com/cgi-bin/tablebuild.pl/ip-key, could anyone point me in the right direction for the CME 8 files?
Thanks!
1 ACCEPTED SOLUTION
Re: Need help locating CME 8 tar install file on CCO
Dont use that download link. That is the old site
Go to
www.cisco.com > login
Support > Download Software > Voice and Unified Communications
Search for 'express'
Cisco Unified Communications Manager Express > 8.0
Hall of Fame Super Gold
CME does not not need any external file to work.
Files are accessories and not indispensable.
Try the 7.1 GUI files, but even if GUi doesn't work, you are not loosing much as the "correct" gui to use is CP.
Go to
Brendan,
Thanks a lot!  That is what I was looking for.
Also when you have a chance please report on the true necessity of upgrading ancillary files
488
