Need help on DOHproptest in unity
Dear Friends. I want to know the use of DOHproptest utility in UNITY. what are uses of tool. pls explain.
Gem
1 REPLY
Re: Need help on DOHproptest in unity
the DOH is a low level DB editor that is designed for technicians and support personnel when troubleshooting unity.
DOHPropTest ("DPT")
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a00801ba0ef.shtml#yyy
Complete these steps for the DOHPropTest (DPT).
1.
Open a command line, and change (cd) to the Cisco Unity installation (typically C:\CommServer).
2.
Enter techtools\dohproptest.
3.
You are prompted for a password. Leave it blank, and clickOK.
4.
Click ignore.
You are now in read-only mode. For troubleshooting purposes, you can use the DPT utility in read-only mode. If further troubleshooting is necessary with this utility, create a case with Cisco TAC.
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
156
